ATF fluid in my 6-speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnecon2001, Jun 17, 2009.
  1. Jun 17, 2009 at 12:47 PM
    johnecon2001
    johnecon2001 [OP] Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Synopsis:
    Input shaft started squeaking, Toyota replaced transmission and clutch under warranty.
    Yesterday, re-attaching skid plate, notice fluid on underside of tranny. Followed fluid up to see residue on the back of the motor where the transmission mates up. It's red. Manual transmission fluid isn't read. Neither is gear oil.
    Called Toyota to make an appointment. Asked why fluid was red, "Sometimes ATF is better for the synchros than the MTF or Gear oil".
    Thoughts?
  2. Jun 17, 2009 at 12:49 PM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    Someone screwed up and didn't know what they were doing.
  3. Jun 17, 2009 at 12:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That sounds like bullshit to me. If ATF was better- Then it'd just be TF and it'd go in all of them.
    Either way they need to fix the leak....Any problems with driving it??
  4. Jun 17, 2009 at 1:07 PM
    johnecon2001
    Phoenix, AZ
    Recently, there's a small lurch when I start going. I'd assume it's low on fluid, since the motor mounts look good and I can feel it move in the shifter.
  5. Jun 17, 2009 at 1:39 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    ruh roh.... sounds like somebody made a boo boo.... and they better be taking care of that shit while giving you a free item from the Turd shop!
  6. Jun 17, 2009 at 1:41 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    That does not sound right. These stories are why I am not trusting the maintenance of my truck to the "Toyota Expert Technicians"
  7. Jun 17, 2009 at 1:53 PM
    johnecon2001
    Phoenix, AZ
    I never really asked questions after they replaced the entire thing because it was working fine, and the initial problem was solved.
    But I'll be on their ass about putting in the fluid I want this time. Redline 75w90 prease.
  8. Jun 18, 2009 at 9:27 AM
    Marazzito
    Marazzito Well-Known Member
    Dublin, CA
    07 DC TRD Off-Road 4x4
    TRD Exhaust, AFE Cold Air Intake, URD Short Shifter, OME 886 HD Lift OME Rear Springs With XL... TRD Supercharger Coming Soon.
    Redline MT90 is the best in our transmission's.
  9. Jun 18, 2009 at 10:03 AM
    jokerjp
    jokerjp Active Member
    central IL
    TRD off road rugged trail
    My old S-10 used Synchromesh Transmission Fluid (GM P/N 12345349) which was essentially ATF in the manual transmission. So the dealer wasn't 100% wrong that some manuals do indeed call for ATF.
    This doesn't excuse the dealer in this case....just food for thought!
  10. Jun 18, 2009 at 10:07 AM
    DanGer
    Why is there always someone posting rational points when we are in our "burn the dealer at the stake" mood
  11. Jun 18, 2009 at 10:27 AM
    johnecon2001
    Phoenix, AZ
    lol
    This dealer is one of the best by me too. Doesn't hesitate to do TSB's etc.
  12. Jun 18, 2009 at 2:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You should've asked him...... "SHOW ME IN THE MANUAL where it states to use ATF in my MANUAL transmission"
  13. Jun 18, 2009 at 3:00 PM
    Riceman
    Riceman Well-Known Member
    Ellijay, GA
    04 Ford Ranger FX4
    Ford uses ATF in most of their transmissions, Auto or Manual. Check the owners manual and see what it says, I would go by the manual.
  14. Jun 18, 2009 at 3:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I agree this is a screw up....If ATF was meant to be in the manual tranny, then it would say so in the book....
    FWIW, My Dodge 2500 6 speed takes ATF also.....So does the transfercase.
  15. Jun 18, 2009 at 5:20 PM
    johnecon2001
    Phoenix, AZ
    I've got an appointment Monday morning, so I'll voice my concerns and requests then (fix leak/lurch, refill with Redline + rental car).
  16. Jun 18, 2009 at 5:23 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I know Chrysler ran ATF in some of their manuals. I think somebody boobooed at Toyota.
