ATF fluid-WS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grantfire319, May 2, 2009.
  1. May 2, 2009 at 8:13 PM
    grantfire319
    grantfire319 [OP] Well-Known Member
    KENTUCKY
    05 DOUBLE CAB TRD SPORT 4.OL
    Secondary Air Filter removal. More to come hopefully.
    From Valvolines website:
    Product Specs
    Recommended for use where the following fluids are specified:
    Ford MERCON®, MERCON® V, MERCON® SP and LV
    GM DEXRON, DEXRON II, III and VI
    Toyota and Lexus Type T, T-III, T-IV and WS
    Allison TES 295 and 389
    Nissan Matic-D, Matic-J and Matic-K
    Honda and Acura ATF Z-1 (except CVT)
    Mercedes NAG-1
    Mitsubishi Diamond SP-II and SP-III
    Kia SP-II and SP-III
    I have been reading on BITOG, and the low viscosity WS has. Any reports on Max life ATF????
  2. May 2, 2009 at 9:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Personally, Im gonna stick with the Toyota WS fluid. I have seen many that "SAY" they are compatible, only to cause issues.
  3. May 3, 2009 at 10:23 AM
    grantfire319
    KENTUCKY
    Thanks Chris!! I guess I'm partial to Valvoline since I work for them. I get to see and tour the products lab once or twice a year and its pretty amazing all the stuff they do back there. I know all the tests they run on fluids. One concern though:
    I dont know the "viscosity" of MAX ATF as compared to WS. I researched on BITOG and couldnt find it.
    I can also get MAX atf for basically free.
    Any info on the viscosity of these two fluids. I'm sure I can find it at work, but I am off untill Tuesday and wont have access to any of the stuff???
  4. May 3, 2009 at 10:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No idea on the viscosity. Sorry...
  5. May 3, 2009 at 6:42 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, Toytec AAL, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Toyota Wheel Locks, Extang Trifecta Cover, Fumoto Drain
    So what is the scoop with Valvolines supposedly fully Synthetic oil. Is it just a type III severely hydrocracked oil? Or is it truely a synthetic PAO or ester based type IV or better?
  6. May 4, 2009 at 4:12 PM
    grantfire319
    KENTUCKY
    Found out today that MAX ATF has a Viscosity of 7, not 5. It doesn't meet the recommended viscosity, but does meet all the other requirements.
  7. May 4, 2009 at 4:16 PM
    grantfire319
    KENTUCKY
    Don't know exactly man. I'll have to research some stuff at work on your specific question. Luckily, I'm not one of the Chemist back there. What I do know, is that the lab that tested the Mobil 1 vs Synpower, is an independent lab with no ties to Valvoline. I also know that they tested the crap out of synpower oil in abunch of "oil tests." We have an awesome R&D lab, and chemists that are top notch and smarter than I'll ever be. I will try to find you some info.
  8. May 4, 2009 at 6:39 PM
    Armkb
    09 TRD Sport DCLB
    Thanks. Hope you can find out for all of us here at TW!!
