ATF flush and change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Oct 26, 2011.
  1. Oct 26, 2011 at 6:45 PM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I've changed front, rear, and transfer case fluids but my ATF just seems too much. Dealer says I will be paying $70 in labor to flush and change. I've rebuilt ATV and Dirtbike engines but ATF and cars just aren't my cup of tea. Is it easier than I think it is? (I've seen the threads for it too)
  2. Oct 26, 2011 at 6:53 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Its way easy!
    1, Open fill plug
    2, Open drain plug
    3, Drain Fluid
    4, Pump new fluid in (I believe its 3-4quarts)
    5, Do AT Temp procedure - its described in the sticky
    6, Open check plug - should be small trickle coming out
    - if any fluid doesnt come out, add fluid and go to step 5,
    - if fluid gushes out, let it drain until its small trickle
    Bam, you just saved $70...
  3. Oct 26, 2011 at 6:55 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    2010 4 X 2 Regular Cab
    Chrome exhaust tip
    There are ways to flush an automatic your self, but you you always run the risk of the transmission pumping out the fluid faster than you're adding it. That can cause serious damage. I would take my truck to a mechanic with the proper machine to do a transmission flush.
