ATF
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scooter66, Mar 2, 2016.
  1. Mar 2, 2016 at 6:56 AM
    Scooter66
    Scooter66 [OP] Member
    Scott
    2016 Silver Tacoma 4x4 SR5 Double Cab
    Stock until I need tires
    After reading a lot of posts I'm wondering if this may be a way to make sure your fluid is at the right level. You will need a way to check temp (still waiting to hear a 2016 step by step temp mode trick). First add a 1/2 quart and then put instrument cluster into temp mode. When truck reaches checking temp then pull the check plug. If low then fluid won't come out. If too full from the 1/2 quart then let excess flow out (keeping an eye on the temp). If the fluid slows to the trickle (see video) AND you're still within the checking temp range then you have the correct ATF level. Repeat if your fluid was low (after the tranny cools off). Why did Toyota make the checking temp below the normal operating temp?? (Rhetorical Question)
  2. Mar 2, 2016 at 6:59 AM
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    What video?
  3. Mar 2, 2016 at 7:02 AM
    Scooter66
    Scott
    Google it for now, and if you find it, take the test at the end. I will add a link later.
  4. Mar 2, 2016 at 7:45 AM
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    It seems like you are basically describing the official procedure:
  5. Mar 2, 2016 at 9:12 AM
    Scooter66
    Scott
    I don't think Toyota starts off by adding a 1/2 quart. If you think your low, and you add a 1/2 quart you may be able to do this in one step; otherwise we are all sitting around waiting for the fluid to cool down. The dealerships have to have your truck for hours just for that reason. Toyota did come up with a special tool that basically increases the height of the overflow tube. An IR temperature gauge may be a good way to check temps since the steel pan is relatively thin and steel is a good conductor of heat. I'm tempted to install a thermowell to the pan if I can find one.
    You Tube - Toyota Transaxle Fluid Level Check - No Dipstick
    https://www.youtube.com/watch?v=cNcecuGzTDg
    Garyji likes this.
  6. Mar 2, 2016 at 10:52 AM
    oz90630
    oz90630 Active Member
    Oscar
    TrdAC
    I wish for an aftermarket mode to the AT pan, where the check ‘tube’ is changed for one where the height is correct for the ATF at normal operating temperature, with a side benefit of a fully open thermostat.
    That would simplify checking the ATF for both, the end consumer and all shops w/o the special tools, in less time.
    Toyota please read: Simplicity is the name of the game...
    eldedo likes this.
  7. Mar 2, 2016 at 11:32 AM
    Scooter66
    Scott
    Next time I'm getting a manual transmission!
  8. Mar 3, 2016 at 9:04 PM
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    Or, if you're in Mexico, a manuel transmiciones.
    transworldmoto likes this.
  9. Mar 3, 2016 at 9:29 PM
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    Totally unnecessary, but so NEEDED in this thread
    Heepspo[QUOTED] likes this.
