Atkinson Engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jmar180, Oct 8, 2022.
  1. Oct 9, 2022 at 10:40 AM
    #41
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Coming from a 5th gen 4Runner to my current 2017 last winter I was like WTF just about every time I drove it. 15k miles later it just seems normal. However I will likely tune it. I like the idea of the gear lock tunes so you can keep it from downshifting. Most of the 17 Toyota 4x4's I owned in the past were manuals. But since the second gens I just don't like the ratios of the six speed. I had an 05 2.7 I bought new with a 5 speed and loved it. Every time I drove a six speed V6 I didn't like it. And I really would prefer a manual. But you can't buy a DCLB manual anyhow.
  2. Oct 9, 2022 at 10:52 AM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t understand - why are folks against the automatic trans downshifting and why do they want a gear lock tune that keeps them in a taller gear for passing? Isn’t that the whole purpose of the automatic, to choose the gear that hopefully makes the most sense for the scenario? My frustration with automatics comes from them not wanting to downshift when I need them to.
    The automatic Tacoma has a very tall set of 5th and 6th ratios combined with a motor that makes very little power down low….it needs to downshift. I just can’t imagine getting a gear lock tune that keeps me in 5th or 6th when the motor is struggling and needs to go to 3rd or 4th for the situation.
    What am I missing? Keep in mind I have absolutely no experience behind the wheel of an auto Tacoma so besides the complaints here (which are all over the map), I have no idea how they drive.
  3. Oct 9, 2022 at 4:25 PM
    #43
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Some people (not you) assume gear hunting equates to downshifting. So when they hear about it on here they pay attention to their next drive uphill and see that it downshifts. They then believe there's an issue when in reality there isn't any problem at all. The exception being early 3rd gens having actual gear hunting where cruise control is set on the interstate and the truck will constantly upshift and downshift. That was pretty much resolved via TSB's.
    My biggest complaint are tunes that separate the downshift at interstate speeds so much that it takes a lot of pedal input to maintain speed up step hills or to even gain speed when traveling on the interstate, just to "eliminate" "gear hunting". *Insert air quotes here*
    BLtheP[QUOTED] likes this.
  4. Oct 9, 2022 at 4:47 PM
    #44
    BLtheP
    Plano, TX
    Thanks, that’s about what I figured. Hunting is annoying, downshifting for a reason isn’t. Factor in how tall the ratios are and it just makes sense. I’d regear a stock auto if I had one just for much better drivability but I’d guess they don’t really have programming issues like the TW masses seem to think.
    ktbell444[QUOTED] likes this.
  5. Oct 9, 2022 at 5:11 PM
    #45
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I smiled.. Didn't I ask for early downshift on WW?
  6. Oct 9, 2022 at 5:17 PM
    #46
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    My 22’ has just over 1000 miles now and it’s fine. I am used to the ZF 8HP in my M340i and also the 5th gen 4Runner. Initially, I disliked the 6AT due to it shifting too early and then having to downshift immediately, and also occasionally hunting. But after driving it a while it really does modify the shift pattern. It doesn’t shift too early anymore and is totally fine. It’s not nearly as fast or as smooth as the BMW (obviously) and is similar to the 4Runner.
  7. Oct 9, 2022 at 5:18 PM
    #47
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Sure did! But my goal isn't to just make you smile Vlady, I want to bring tears to your eyes while you smile. It'll happen one day. ;)
    Vlady[QUOTED] likes this.
  8. Oct 9, 2022 at 8:02 PM
    #48
    Vlady
    Issy, WA
    Looking forward..
  9. Oct 10, 2022 at 5:37 AM
    #49
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    The new f150s have had a 10 speed trans since 2017/2018...
  10. Oct 10, 2022 at 6:17 AM
    #50
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I have a hard time understanding these automatic transmission complaints. My truck performs smoother than some in the past with perfectly timed shifts when its needed, even the cruise control works exactly like the one did on my tundra ....no complaints there either.
    Greene368 likes this.
  11. Oct 10, 2022 at 6:50 AM
    #51
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Same here no complaints at all about my Taco AT but I will tell you that when I do boot it she goes crazy, sometimes very scary.
  12. Oct 10, 2022 at 7:45 AM
    #52
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    In the commercial F250 line, the 6-speed is still standard, the 10 is only in the fancier lines. Should have specified I guess. The 6.2L V8 engine config still comes with the torqshift-g 6-speed automatic even in 2023. It does the job.
  13. Oct 10, 2022 at 7:53 AM
    #53
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I’d rather just have the 6 speed automatic than a 10 speed or whatever the next trend for auto trannies is. All the people who complain of this trans shifting too much with 6 gears, how do ya think it’s gonna shift with 4 MORE gears, lol? And say goodbye to S mode with a 10 speed (which I love and use all the time on my truck). These aren’t school buses or 18 wheelers, they don’t need 10 fugging gears in a mid size pickup. It’s all becoming like men’s razors… how many blades can we fit onto one little razor to shave the same face.
    Tacos4Runnin likes this.
  14. Oct 10, 2022 at 7:55 AM
    #54
    Tacos4Runnin
    Tacos4Runnin Well-Known Member
    Okanagan…eh
    2021 TRD-Sport AG/MT
    …but its a Ford…
    :poking::crapstorm::stirthepot:
  15. Oct 10, 2022 at 7:57 AM
    #55
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Buy a manual.
    whiseve likes this.
  16. Oct 10, 2022 at 8:07 AM
    #56
    Gord0
    Gord0 Well-Known Member
    I wish I bought a manual… that is until the other day when I threw a set of 255/75/17’s on, night and day difference in overall drive-ability. I do have the OTT tune but didn’t seem to help my ‘21 TRDOR much, shifting was still erratic.
    The change in tire size (SL load Duratracs) seemed to nail the sweet spot for my truck.
  17. Oct 10, 2022 at 8:09 AM
    #57
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Shifting still bad with OTT? Wow.
  18. Oct 10, 2022 at 8:17 AM
    #58
    Tacos4Runnin
    Okanagan…eh
    Talk to ur tuner. My truck with OTT shifts perfect
    Glad to hear this tire size works well
  19. Oct 10, 2022 at 8:27 AM
    #59
    Gord0
    I did talk to my tuner, we tweaked it twice. All OTT seemed to do was hold the shift points longer. That being said it felt like an overall improvement immediately after the tune, but it seemed to revert back after a few weeks! I do live in a hilly area with very windy roads so the shifting issue is very noticeable.
    Honestly this tire size + tune combo is perfect for me. I was seriously considering selling the truck due to how poorly it drove.
  20. Oct 10, 2022 at 8:39 AM
    #60
    Tacos4Runnin
    Okanagan…eh
    Glad to hear
    Any photos of the rig with the new tires installed?
