Atmospheric Pressure Sensor on 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KC2MDN, Mar 13, 2021.
  1. Mar 13, 2021 at 12:29 PM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    Does anyone happen to know where the ECU gets its Atmospheric Pressure Reading from ? Which Sensor ? Where is it located?
  2. Mar 13, 2021 at 2:03 PM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    IMG_4103.jpg [​IMG]
    Here is a list of the PID's for the Truck......Notice the Atmospheric Pressure is 36.9.......That's definitely not the case...Trying to figure this out
    SR-71A likes this.
  3. Mar 13, 2021 at 2:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm pretty sure if it's used it's a calculated value and there's no actual sensor.
  4. Mar 13, 2021 at 2:10 PM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    So this all stems from a P0453 Code......Canister Pressure Sensor Voltage High......But the Voltage reading all the way back to the ECU is well within Limits to not throw a code.....Could I possibly have a bad ECU
  5. Mar 13, 2021 at 2:38 PM
    Taco'09
    Taco'09 Well-Known Member
    I have only known there to be an air pressure sensor on the 2.7L 2TR-FE, and not on the 1GR. On the 4cyl. it is located on the RH side near the rear of the engine approximately near where the tube from the air box is relative to the the valve cover. Its connector has two wires. Oh, and I remember it being a very expensive sensor.
  6. Mar 13, 2021 at 9:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I would suspect a wiring or sensor problem, here's the service info for that code.
  7. Mar 19, 2021 at 11:19 AM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    DM93....Thank You for that info.....When I backprobed the Sensor all the way to the ECU.....The sensor never retuned a voltage that was "Out of Range".....I always had a voltage that was within the "Usable Range" so there is no reason in my eyes why the CEL would come on
  8. Mar 19, 2021 at 11:35 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cant provide much help as to where exactly it is, but Im pretty sure these engines have one. Somewhere along the intake plenum I would guess, post air filter. I base that on my ScanGaugeII. Normally reads out right around the 100-101 kPa range (somewhere in the range of 29.9 inHg I think)
    Going up into the foothills leads to reading out a lower number. And a severely blocked air filter also leads to a much lower number. I wonder if it is integrated into the MAF unit?
  9. Mar 19, 2021 at 1:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No problem, so did you find where your problem was?
  10. Mar 19, 2021 at 1:11 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I can't find any info on it but there's no external sensor, it's most likely either integrated into the ECM or a calculated value.
    SR-71A[QUOTED] likes this.
  11. Mar 19, 2021 at 1:38 PM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    The calculated part is what Im worried about and believe that may be why I have an ECU Problem......The voltage of the sensor being retuned to the ECU is within limit but the data being interpreted by the ECU is out of range. The sensor I am referring to that I backprobed is the Pressure Sensor in the Charcoal Canister
  12. Mar 19, 2021 at 5:44 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    maybe the sensor is failing intermittently. Does the code come back quickly after clearing?
  13. Mar 19, 2021 at 7:35 PM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    I cant even clear it.....The ECU's interpretation of the data is Out of Range High so it just comes back instantly
  14. Mar 19, 2021 at 7:50 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What voltage are you getting on the signal wire, on a 5v sensor generally a valid range is 0.5v-4.5v.
  15. Mar 19, 2021 at 10:22 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Dm93 likes this.
  16. Mar 19, 2021 at 10:26 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Note that the ATM Pressure reading on the PID is different than the pressure sensor in the canister
    Dm93 likes this.
  17. Mar 19, 2021 at 10:38 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Per the TS recommendations, replace the charcoal canister.
    Dm93 likes this.
  18. Mar 20, 2021 at 6:34 AM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    When I backprobed all the way the way to the ECU connector I was getting 2.9v to 3.1v......Well within the usable range
    6GearT444E.....Thats some great Info...I appreciate that....The charcoal Canister is Brand New from Toyota....Its all making me lead harder towards the ECU now
    SR-71A and 6 gearT444E[QUOTED] like this.
  19. Mar 20, 2021 at 6:40 AM
    KC2MDN
    KC2MDN [OP] Member
    2008 Access Cab V6
    Based on what 6GearT444E is saying makes even more sense as to why I got all these EVAP codes to begin with. If my atmospheric pressure reading is that far off (which now I know comes directly off the ECU) there is no way for the Canister Pressure and the Atmospheric pressure to be close to one another to Satisfy the Sealed and Vented Status of the EVAP System
  20. Mar 20, 2021 at 8:37 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    That’s weird then, it’s likely not the canister usually what happens when they fail is the filter degrades, the purge Valve fails, or fuel gets in from over filling the tank and damages the vacuum pump.
