ATO Dual Battery Tray - 05+ Tacoma's
Discussion in 'Armor Tech Offroad' started by Fire931, Jun 25, 2012.
  1. Jul 19, 2012 at 8:14 PM
    #41
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    subb'd
  2. Nov 13, 2012 at 11:34 AM
    #42
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    To run a dual battery setup, what else do you need besides a tray and 2 batteries? I see people have controllers and isolators.
  3. Nov 13, 2012 at 11:36 AM
    #43
    Namyo
    Namyo -
    :ohsnap: Warning Notice!
  4. Nov 13, 2012 at 11:48 AM
    #44
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    word is he's back....
  5. Jan 17, 2014 at 5:30 PM
    #45
    CallMeCesar
    CallMeCesar Well-Known Member
    So Calif
    2005 4x4 TRD Tacoma
    Are these trays still available?
  6. Aug 26, 2018 at 1:14 PM
    #46
    jcloer1
    jcloer1 Well-Known Member
    Jim
    McMinnville, OR
    2019 White AC TRD OR
    TBD
    I finally got around to painting my set and starting the install. Unfortunately...there are fitment issues in the 2.7L 4 cylinder apparently. I have left a VM (closed as its Sunday) and will update when I have additional info. Really hope we can make this work!
    UPDATE: The tray will NOT be a straight bolt in on the 4 cylinder, BUT...all you have to do is move the fuse block back roughly one inch. This means that you DON'T have to cut that tab off (wish I'd known that ahead of time) but you will have to use self tapping screws to re-mount the fuse block in it's new location.
    I finally have my Mobtown recovery bar installed with the dual battery setup from ATO and Omix-Ada dual battery relay kit! Another note...the three position switch included in the Omix relay kit does NOT fit in the Tacoma switch opening without modifying the opening. It didn't take much mod, just using a razor knife to shave a little plastic off of each of the left and right sides of the opening.
    I will put together a few pics and post them as soon as I get time.
  7. Nov 16, 2018 at 6:11 PM
    #47
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    do you have pics of this? Im about to install this in the next month or so
