ATO Front Skid Plate Intro Sale
Discussion in 'Armor Tech Offroad' started by Fire931, Jan 11, 2010.
  1. Jan 20, 2010 at 10:26 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    lol, thats what I was thinking. I'm in the process of changing out my lift and will have to wait. It looks like a damn good skid so I don't mind paying for the extra protection.
  2. Jan 20, 2010 at 1:03 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i can make some of it back up by selling the AP ones :D....hopefully
  3. Jan 20, 2010 at 1:08 PM
    The_Hodge
    SC
    i know....this one did
  4. Jan 20, 2010 at 1:14 PM
    The_Hodge
    SC
    i havent had any issues w/ it...one small dent and some touched up scratches...just want the extra for when this becomes dedicated trail
  5. Jan 20, 2010 at 1:56 PM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I sold my 3 all pro skids in about one day.
    Now time to get serious
  6. Jan 20, 2010 at 4:37 PM
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    just wanted to bump this back up for the evening crowd.. still got some spaces left guys!!!!!! :D
  7. Jan 20, 2010 at 7:46 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    **Attempts Jedi mind trick**
    For 1st gens you will make.
    :D
  8. Jan 21, 2010 at 10:24 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    Im in on this one... Which means I'll be selling my AP soon =/
  9. Jan 23, 2010 at 7:10 AM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    2 quick questions for armor tech....1. can i still put my aftermarket toyota skid plate over this one(not the one that comes stock with the truck) or once youput yours on then the others go? 2. when you say 6 factory holes does that mean 6 holes that are not being used and i install with bolts you provide or do i need to unscrew bolts thay are holding other things in place and then r-secure? thanks
  10. Jan 23, 2010 at 7:36 AM
    Fire931
    VA
    00 4Runner
    the steps to mount the skid are as follows... remove the factory "skid" and the two long brackets that it bolts to.. then use the same bolts that secured that on to bolt up the new skid.. so yes you do have to remove the factory skid in order to use this one...
    if that dosn't answer your question just let me know...
  11. Jan 23, 2010 at 8:05 AM
    The_Hodge
    SC
    if ur needing a skid like this, u dont want to rebolt the cheap ass aluminum "TRD" skid over it...not unless u want a permanent aluminum skid crunched on top of a real one...but i doubt u can actually do it.
  12. Jan 23, 2010 at 10:04 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    lol
  13. Jan 23, 2010 at 1:59 PM
    Fletcher007
    Fletch
    Phoenix,AZ
    if there are 6 mounting holes total how do the other 4 work. the reason i ask is because i am done jimmy rigging my cars and just want to make sure i take 6 bolts out then put 6 bolts back in and i'm good to go......and thanks jhodge 83 that was going to be my next question!!!!!lol
  14. Jan 23, 2010 at 4:49 PM
    Fire931
    VA
    00 4Runner
    kinda hard to explain where it mounts up if your not looking at it.. but basically there are 6 different locations on the frame that have nuts pre made into the frame.. so we just utilize those locations to bolt up the skid.. it's not "rigged" at all....
  15. Jan 23, 2010 at 6:21 PM
    #35
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Hi Fire931,
    Is this a one-piece skid that will protect both differential and engine?
    I noticed that the floor jack point is covered. Do we need to remove this skid when jacking up the front end?
  16. Jan 24, 2010 at 7:00 AM
    #36
    Fire931
    VA
    00 4Runner
    hey there... yes this is a one piece skid that goes from the very front crossmember under the radiator all the way back behind the front differential.. there is no need to remove it to jack up the truck.. just simply place the jack under the skid and have at it....
  17. Jan 24, 2010 at 7:30 AM
    #37
    drew02a
    San Antonio, TX
    Yeah, if it can take being set on a rock, I think it can handle a lift jack.
  18. Jan 24, 2010 at 7:47 AM
    #38
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    where in VA? If i can drive up, would you skip the shipping?
    Mind you, still theoretical at this point.
  19. Jan 24, 2010 at 7:54 AM
    #39
    Fire931
    VA
    00 4Runner
    sorry have to charge shipping no matter what.....
    kidding.. ofcourse if you drive over there's no shipping... we're located in Lexington so somewhere around 3 hrs from you.
  20. Jan 29, 2010 at 4:05 PM
    #40
    Fire931
    VA
    00 4Runner
    one last bump.... :D
    those of you who have committed already... i'll start taking the actual orders over the weekend and first of the week so we can get this rolling.....
