ATRAC Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacobot14, May 19, 2017.
  1. May 19, 2017 at 5:30 AM
    Tacobot14
    Tacobot14 [OP] Heep Recovery Vehicle
    Ty
    North Carolina
    2015 TRD OR White Tacoma 6MT
    OME BP-51, JBA UCA, SOS Streamline Bumper, SOS Sliders, Toyo AT2 tires, many more.
    Has anyone every tried installing ATRAC on their truck just by buying the parts from somewhere and putting them in yourself? Would it be a big task you guys think? I'm just looking around and there's a 2007 with the full ATRAC system at my local salvage yard... was thinking about making my way out there to make an upgrade for my truck! (I have an 06 with no ATRAC)
  2. May 19, 2017 at 5:46 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I haven't heard of anyone doing it but I'd be interested in seeing it happen. I think you just need the brake booster and the control module. Not sure what else is involved. You'll have to pull the wiring diagram.
  3. May 19, 2017 at 1:56 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    07s didn't have ATRAC. It started in 09
    BassAckwards and shakerhood like this.
  4. May 19, 2017 at 2:06 PM
    Tacobot14
    Ty
    North Carolina
    It was an optional add on starting in 2005 and it became standard on them in 2009, I already went and looked at the truck and it looks so complicated to 1) take off and 2) install on a different truck... may just be worth it to get an ARB locker and call it done
    BassAckwards likes this.
  5. May 19, 2017 at 2:08 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Atrac uses a hydraulic brake booster plus the lines. Between that and the wiring and control module I can not imagine it being worth it.
  6. May 19, 2017 at 2:10 PM
    Tacobot14
    Ty
    North Carolina
    I saw you edited your post... I've done my research and talked to several Toyota specific mechanics about it. But yes, you are right. I don't think it's worth the hassle. More worth to go with an LSD or locker.
  7. May 19, 2017 at 6:43 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Definitely easier, and probably way cheaper going with lockers.
  8. May 19, 2017 at 7:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't think it was an option in 05, I still have the Brochure from my 08 and nothing at all is mentioned anywhere about the ATRAC System, only optional VSC with TRAC.
  9. May 20, 2017 at 6:19 PM
    Tacobot14
    Ty
    North Carolina
    TRAC and ATRAC are the same thing, ATRAC only engages while in 4lo though, or atleast that's how it works on my Dad's 2014.
  10. May 20, 2017 at 6:23 PM
    shakerhood
    Southern Ohio
    They are 2 different systems, TRAC comes on the Sports and ATRAC comes on the Off Road, they use a different style brake booster.
    Norton likes this.
  11. May 20, 2017 at 6:29 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    They are not the same thing. They have a similar function.
    Norton and shakerhood like this.
  12. May 20, 2017 at 8:04 PM
    Tacobot14
    Ty
    North Carolina
    Can you please explain the differences to me then? Here's what I've read and how my friend (mechanic at my local Toyota dealership) explained it to me:
    They both use the brake boosting system to apply brakes on the slipping wheel to basically simulate a locker, TRAC is more road friendly and is engaged is 2hi and 4hi. ATRAC is something you turn on when in 4lo if you want it on. Turned on via the button.
    Thats about all I know for certain. Someone explain it to me please? Also any truck with the TRAC system installed, can EASILY have ATRAC installed because the brake booster is already there, just need the computer system apparently. Again, i got all this from the mechanic, i haven't laid my hands on trucks and done the physical research for it.
  13. May 20, 2017 at 8:19 PM
    moondeath
    Pa, Gardners
    TRAC is similar to ATRAC, but ATRAC is much more aggressive. ATRAC is instantaneous power distribution to the tire that needs traction. TRAC is a bit more delayed response to a tire in need of traction.
    The off-road has a different brake booster for the ATRAC system. The off-road brakes are way more sensitive, and have a feeling of 'over reacting' in my opinion. Its a feeling of all or none.
    Tacobot14[QUOTED][OP] likes this.
  14. May 20, 2017 at 8:55 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    The Offroad model has ATRAC. It uses a hydraulic brake booster instead of a pneumatic one to regulate the wheels so it is much stronger and faster as stated above.
    Tacobot14[OP] likes this.
  15. May 22, 2017 at 9:22 AM
    Gincoma
    Salt Lake City UT
    Still not true bud. Didnt come out until 2009 period. Only standard on TRD Offroad models that's it nothing else.
  16. May 22, 2017 at 9:40 AM
    Tacobot14
    Ty
    North Carolina
    Then why did this 2007 have it? I doubt the owner retrofitted his brakes to install it. I'm just extremely confused. EVERYONE has different answers to this question it seems like. Guys from the dealership told me ATRAC was supposed to be on the 2004 tacomas but because they were releasing the second gen the next year, they saved it for the 2005. Again, this is from the guys at the dealership.
  17. May 22, 2017 at 10:09 AM
    Gincoma
    Salt Lake City UT
    ATRAC was in other Toyota vehicles like the Land Cruiser or 4Runner before it went into the Tacoma in 2009. You were misinformed. You are probably thinking of Trac which is totally different then ATRAC.
    shakerhood likes this.
  18. May 22, 2017 at 12:04 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Guys at dealerships are idiots and rarely know about the product line they work for. I got into a huge argument once with a salesman telling me he has a 4 door bmw m3 e46 body style. I told him that is amazing considering they never ever made a 4 door.
    Norton likes this.
  19. May 22, 2017 at 12:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    for the confusion on the "option" of atrac on the 05-08 models. it was NOT an option. The option you are referring to is the VSC option which actually uses the same all in one brake booster / master cylinder / abs module as the atrac enabled 09+ TRD OR 4x4, but the 05-08 truck regardless of TRD trim that were optioned with the VSC (vehicle stability control) were not programmed for atrac.
    After 08 VSC was NOT an option, and In 09 VSC became standard and code was written for the separate ABS module / vacuum assist master cylinder found on the non TRD OR 4x4's to enable VSC on those truck, and the electric brake booster code was re-written to enable atrac for the TRD OR 4x4's.
    shakerhood, Norton and Tacobot14[OP] like this.
  20. May 22, 2017 at 2:00 PM
    Gincoma
    Salt Lake City UT
    What he said. :)
