ATrac
Discussion in '3rd Gen. Tacomas (2016-2023)' started by azexplorer2, Oct 25, 2016.
  1. Oct 25, 2016 at 2:20 PM
    azexplorer2
    azexplorer2 [OP] Member
    Ray
    Gilbert, Arizona
    08 4 door 4x2
    Looking at a 2016 Taco. 4X4, Auto. No ATrac button just a knob on the overhead with 5 settings. Do any of them active an ATrac system?
  2. Oct 25, 2016 at 2:25 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Thechief86 and Joe23 like this.
  3. Oct 25, 2016 at 2:34 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Joe23 likes this.
  4. Oct 25, 2016 at 2:41 PM
    RyanL
    Indiana
  5. Oct 25, 2016 at 2:42 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    My truck came with an Atrac player as well as cassette.
  6. Oct 25, 2016 at 2:49 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    RyanL[QUOTED] likes this.
  7. Oct 25, 2016 at 2:56 PM
    RyanL
    Indiana
  8. Oct 25, 2016 at 10:41 PM
    azexplorer2
    Ray
    Gilbert, Arizona
    08 4 door 4x2
    Ok, So if the only way to get ATRAC is with the manual transmission that's fine. Then what are the 5 or so settings on the little knob on the overhead console?
  9. Oct 26, 2016 at 5:21 AM
    Outlier
    Outlier I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
    It's your CRAWL control unit. I would search threads on that.
    How can you have joined this site in 2009 and only have posted 7 times?
  10. Oct 26, 2016 at 5:44 AM
    WyomingSkidmark
    WyomingSkidmark Well-Known Member
    I joined last week and already have more than 7 posts. And yes, the cassete player only comes in the manuals, because we're old school and miss the Reagan years
    Riding Dirty likes this.
  11. Oct 26, 2016 at 7:59 AM
    RyanL
    Indiana
    It sounds cliché, but check out the section in your owners manual about those Multi Terrain Select / CRAWL settings. It's actually pretty useful.
  12. Oct 26, 2016 at 8:03 AM
    FX Jenkins
    FX Jenkins Well-Known Member
    NOVA
    2010 Taco OR, 2010 4Run Limited, 2017 TRD Pro
    Just when I thought I somewhat understood a-trac, and used it successfully on several occasions, out comes the MTS. The crawl I'm cool with in that the "knob" itself really only controls the speed at which the crawl control system works. What seems to be "overthought" by Toyota is the MTS. I just don't see how there can be that much difference in how this system operates for 1) Mud & Sand 2) Loose rock 3) Mogul 4) Rock and Dirt & 5) Rock.
    I'm sure there is some science, math, and timing differences but does it really make a difference between 2) Loose rock and 4) Rock and Dirt. How about snow? I think per manual that falls in category 1) Mud & Sand. But this is the only part of the system that seems overkill in that it took a-trac and basically assigned it 5 different variables.
  13. Oct 26, 2016 at 8:06 AM
    RyanL
    Indiana
    MTS is extremely effective though ... cause everyone was super stoked about it when the 3rd gen came out. Functional? Maybe. Effective marketing? You bet!
    Thechief86 likes this.
  14. Oct 27, 2016 at 8:31 AM
    azexplorer2
    Ray
    Gilbert, Arizona
    08 4 door 4x2
    Thanks for all the input. However I still can't figure out if "The MTS or Crawl" uses any sort of front axle traction control to do it's job. I don't own a 2016 Taco so can't read the manual. Just looking for info to see if I want one. And since Outlier asked why I only have very few posts here, it's very simple. 1. I've never done many mods to the several Tacos I've owned so don't have many questions and 2. I usually can find answers in the trucks manual.
    Thanks again. Guess I'll see if I can find an Owner's Manual on line and decide if I should shell out $38,000 for a new truck.
  15. Oct 29, 2016 at 8:23 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    The mts is like atrac. It does work the front axle as well as the rear
  16. Oct 29, 2016 at 9:32 AM
    azexplorer2
    Ray
    Gilbert, Arizona
    08 4 door 4x2
    Thanks Paul. I've been doing some reading like I usually do before shelling out big bucks of anything and came to the conclusion that MTS does work like atrac, maybe even better since you can set the amount of braking. With my 2013 I once had a left front off the ground by a foot and even with the rear locked I had to add a little manual braking to assist atrac to do it's job. Still think I'll wait to hear from other owners before trading in the 2013.
  17. Oct 29, 2016 at 9:54 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    No, if he is talking about ATRAC, he means MTS. MTS is 5 settings of ATRAC. The dial is for both but there is one button for MTS and one for Crawl Control
  18. Oct 29, 2016 at 10:22 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    "a knob on the overhead with 5 settings."...That makes no sense to me as only the Atrac system should have the crawl\MTS as opposed to a regular 4X4, unless something's changed.
    The only models I know that come standard with it are the OR and limited. Others may correct me on this. The regular 4x4 on other models like my 4x4 SR5 have Trac/auto lsd and VSC controlled via regular ABS system.
    But in the ATRAC equipped models, you're looking at a more advanced TRAC system. It also comes with and integrated all in one assembly, in which the Master brake cylinder, brake booster and ABS module are integrated and replaceable as one unit if any one should fail. It may also cost about $5k retail if any component in it should fail. I've had them on my 4R and never had an issue and they work wonderful.
    But, with the right tires and some skill level, I can pretty much negate any advantage it may have over mine, so I'm not feeling like a step child here, but looking at a much lower part cost if it should fail out of warranty.
    Hope that helps
    Cheers!
  19. Jul 29, 2020 at 4:58 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    These all sound like very complex systems, but they aren't as complex as you think. A-trac and crawl control all work off of the ABS system. Crawl control is essentially a cruise control utilizing the A-trac system. The MTS part basically adjusts the sensitivity of the ABS system. For example: rock mode won't allow for much slippage before ABS kicks in because it'll give you the best traction. Sand mode will do the opposite in that it'll allow much more slip before ABS kicks in.
    My understanding is that the manuals don't offer crawl control, so they have A-trac instead while the automatics have crawl control. They're essentially the same systems, but work in slightly different ways.
    Hope that helps, in case you didn't get your answer since this was posted.
