ATTENTION ALL GEAR HEADS!
Discussion in 'Performance and Tuning' started by TMASS, Jun 20, 2012.
  1. Jun 20, 2012 at 2:57 PM
    TMASS
    TMASS [OP] Well-Known Member
    T-MASS
    OREGON
    2008 4X4 TOYOTA TACOMA
    I'll update soon
    Ok Gentleman,
    I'll get straight to the point. I have a 2008 4.0l V6 six speed manual Tacoma. I'm currently running 33" Duratracs with a 3" Icon lift. I also have CBI's Bushmaster 2.0 rear bumper with the swing away tire carrier and jerry can holder(Two cans). I also have CBI's Bolt on Rock Sliders. Both rock sliders together weigh about 80lbs. The bumper with the tire and two full jerry cans weighs close to 200lbs. I've been running with this setup for almost a year now and I haven't noticed too much lag or drop in power. The reason for this email is because I'm about to add a front plate bumper w/winch that will weigh close to 200lbs as well(Which will be a total of almost 500lbs extra.)
    My question is will I need to change my gearing? I'm currently running with the 4.11 Ring & Pinion setup. Will I need to move to the 4.56 or 4.88? Any information will be greatly appriciated.
    p.s. I recently had a local dealership replace my throw out bearing under warranty. Makes me wonder if all this extra weight helped speed up the process.
  2. Jun 20, 2012 at 3:09 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If you tow...maybe. I've got 3.73s and 35s. I don't find it too bad other than horrible milsge.
