Attn. 09, 11, 12 Headlight lense will melt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808brian, Oct 10, 2011.
  1. Apr 25, 2012 at 8:35 PM
    #81
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    No idea's if this will happen on an 08?
  2. Apr 25, 2012 at 8:38 PM
    #82
    rcfreak201
    rcfreak201 Well-Known Member
    Nah, its only with the daytime running lights being the turn signals, newer models only unless you do the mod to have them on but you dont have it so dont worry:)
  3. Apr 25, 2012 at 8:42 PM
    #83
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    WELL. chris (csjumper) is going to mod the DTRL for my truck so i can run the white DTRL's..
    Think it'll melt?
  4. Apr 25, 2012 at 8:44 PM
    #84
    rcfreak201
    ohh, now that i dont know. They are LEDs so its not as hot as the normal bulbs but i really dont know, i think it should be fine though.
  5. Apr 25, 2012 at 8:46 PM
    #85
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Fosho. Make my damn BHLM.
  6. Apr 25, 2012 at 9:59 PM
    #86
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    I found my other post that detailed this:
  7. Apr 25, 2012 at 11:09 PM
    #87
    flatfeet
    flatfeet Well-Known Member
    Rob
    Hilo
    09 TRD Sport 4x4 DBL CAB
    RCD 4.5 lift, 18x9 BFD, 305/60-18 Mickey Thompson ATZ's, projector HIDs, TRD exhaust, AFE intake, onboard air, led dash mod, train horns.
    My 09' DTRL melted both plastic sheilds at about 27,000 miles. Dealer replaced them but one thing I noticed about the NEW headlights, when I opened them up during the projecter mod, the lense is now made of GLASS!
    Those of you who had them replaced by your local dealer recenlty, go out and shine a flashlight in there. You might have the glass ones too...
  8. Apr 25, 2012 at 11:29 PM
    #88
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My 09 lenses are still fine at 60 000 kilometres
  9. Apr 26, 2012 at 1:47 AM
    #89
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I have a 2010 with oem from day one DTRL. The DTRL lens has not changed or melted yet, but the outer clear lens (oem black tinted) on both sides is showing small cracks. Not from impact, but rather typical plastic crazing cracks.
    Anyone else had concerns yet with the outermost lens?
    PK
  10. Apr 26, 2012 at 9:19 AM
    #90
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    This makes me glad I don't have daytime running lights!
  11. Apr 26, 2012 at 8:05 PM
    #91
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    2010 dtrl's are the flasher bulbs, not the turn signals. so are they still suspect?
  12. May 1, 2012 at 5:47 PM
    #92
    Stevo8
    Stevo8 New Member
    Stevo
    Dallas, TX
    2011 Texas Edition Super Sport
    Not yet..
    Hey guys.. Just purchased a 2011 with the dtrl and am interested in disabling this feature before damage is done to the lens. Has anyone heard how to 'turn it off' easily?? I had a friend with a 2009 that had extreme discolorization and warping in the turn signal lens.. any info would be great! I have my first oil change with the dealer Thursday and will do some inquiring and let ya'll know..
  13. May 1, 2012 at 5:54 PM
    #93
    Stevo8
    Stevo8 New Member
    Stevo
    Dallas, TX
    Not yet..
    Dtrl stealth mode?? How is this done?
  14. May 15, 2012 at 3:52 PM
    #94
    TulsaTaco
    TulsaTaco New Member
    clark
    tulsa
    2019 TRD Double Cab
    Sorry guys, I'm new to the TW forum and needing to catch up a bit here. I have 2009 Dbl Cab w/ 55k miles with the DRL/Turn Signal Bulb issue. My driver's side bulb has now cracked the small lens all the way through and its trapped in there in two pcs. (see pic w/ bulb removed).
    Questions: Is there a solution for this crap? Can you replace just the lens inside the headlight assembly? What are people doing if warranty isn't an option?
    Thanks Much.
  15. May 15, 2012 at 4:14 PM
    #95
    Dobri56
    Dobri56 Well-Known Member
    Dan
    Massachusetts
    2012 trd sport longbed
    Smitty Bull bar, PIAA 540, MBRP turn down exhaust, Tractor trailer tool box. Black headlight mod, fog light mod, TRD seat covers, tacoma floor mats, Recon under tailgate light
    Just swap to LED bulbs its a cooler light and it should not burn. I'm only reading page one so if someone said it on the other pages there ya go
  16. May 16, 2012 at 7:59 AM
    #96
    TulsaTaco
    clark
    tulsa
    2019 TRD Double Cab
    thanks Dobri-
    Sorry to keep grinding the details. I can do the LED bulb swap with no problem, but is there a way to replace the already cracked lens(es) inside the headlight assembly? Thanks Much.
  17. Jun 13, 2012 at 2:24 PM
    #97
    spinso71
    spinso71 Active Member
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    How do you prevent the LED's from blinking fast? I put in two replacement LED's on my DRL. Blinks fast. Is this a hazard to the electronics in the long run if I decide to eat the 15 bucks for the lights and continue using them?
  18. Jun 13, 2012 at 2:27 PM
    #98
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    My dad's 09 DRL's have done this, and it bugs the crap out of me every time I see it. I haven't said anything to him about though. Haha
  19. Jun 13, 2012 at 4:55 PM
    #99
    Dobri56
    Dan
    Massachusetts
    mine are doing that as well. I'm lazy to fix it but I'm sure its just putting 2 more in the rear that are LED as well.
  20. Jun 13, 2012 at 8:21 PM
    #100
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is because of the bulb outage sensor circuit: Here is the answer you seek:
    http://www.stu-offroad.com/electrical/led1/led-5.htm#q2
