ATV beadlocks.
Discussion in 'All Terrain Vehicles' started by BlueT, Feb 19, 2013.
  1. Feb 19, 2013 at 9:37 AM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So my ATV or UTV had filed to plow 3 feet of snow. :mad:
    It came with silly very narrow tires.
    I am thinking if I can beadlock wider and little bigger (14 inch) wheels and get slightly bigger tires, atleast ATV would not sink into snow and allow me to eat at larger amount of snow.
    I only found IPT making beadlocks for ATV do you know any other company?
  2. Feb 19, 2013 at 9:39 AM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    ITP makes really good tires! they may be expensive but I believe they are worth it.
    no personal experience with the beadlocks, but I do have a set of 25" mudlites and I love them
  3. Feb 19, 2013 at 9:50 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Have you considered tire chains? A 4wd ATV with chains can be a beast in the snow.
  4. Feb 19, 2013 at 10:02 AM
    BlueT
    NorthEast
    I did but chains will give me nothing. at 3 feet of snow ATV had traction on the snow but would immediately sink into the snow bottoming out. Chains would make it dig deeper and quicker and I want the ATV to stay on top of snow. The only way to get that is with bigger, wider tires and less air pressure but I am already at 5 psi so need bead-locks and ability to run at 0 PSI.
    I am surprised how small amount of people runs bead locks.
  5. Feb 19, 2013 at 10:18 AM
    Pugga
    Massachusetts
    F-150 Mod
    The chains almost act like a paddle to keep the ATV on top of the snow. We always ran them and it was impressive what the ATV's would claw it's way through. We had a stock Honda 300 4x4 though. ATV's these days are getting ridiculous, monster engines which make them a lot heavier than the ones we had growing up. Hell, back then a 500 was a beast! :eek:
  6. Feb 19, 2013 at 12:59 PM
    BlueT
    NorthEast
    No man, old ATV's would come with wider tires from factory, now those companies are just cheap so they give you street racing wheels. My ATV is 500 :D it has plenty of power but can't stay on the top of snow. Only sad part those beadlocks are crazy expensive and with tires looks like over a grand to be spend even on cheapest ones.
  7. Mar 18, 2013 at 12:52 PM
    BlueT
    NorthEast
    Ok so I was posting somethign else and realized i forgot to post here.
    ITP beadlocks are the only item I found fitting my Kymco but those seem to have beadlocks only on the outside.
    "F#$% !!" fake $hit.
    So new plan hatched in my head.
    Fuse powersports supposedly sells beadlock kit. I would need ttwo of them to convert steel RIM's into beadlocks
    Anybody try that kit?
    http://www.youtube.com/watch?v=H17Pg--PBqQ
  8. Mar 23, 2013 at 7:54 AM
    Smallwallman
    Smallwallman Active Member
    DWT makes bead locks
  9. Mar 23, 2013 at 9:03 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    King George, VA
    2017 Silverado
    BRO'D Edition
  10. Oct 30, 2013 at 2:27 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    pretty old post. but something i noticed when i kinda looked at beadlocks is most for atv’s and utv’s only have the bead lock ring on the out side, and not on both sides. I also read a lot on them and there was/is not really a big need for both sides to have lock rings, at least not for ATVS and UTVS.
