ATX Mojave fitment
Discussion in 'Wheels & Tires' started by dylandercole, Nov 30, 2009.
  1. Nov 30, 2009 at 10:51 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I noticed that the ATX mojave backspacing is 4.48, I was just wondering if thats too much. I really want to avoid rubbing when i get my 285s so is 4 inch backspacing really ideal or is it a little difference from the 4.48?
  2. Nov 30, 2009 at 11:09 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I have no issues running these rims but i run 265-70-16 tire
  3. Dec 1, 2009 at 12:23 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    most everyone running 285's run a 4.5" on an 8" width rim
  4. Dec 1, 2009 at 10:12 AM
    dylandercole
    Dylan
    oh I was under the impression the stock rims are 4.5 backspacing thats why aftermarket wheels or wheel spacers are required. I thought that 4'' back spacing was what most people ran. thanks for clearing that up
  5. Dec 1, 2009 at 11:06 AM
    dylandercole
    Dylan
    wait i thought that the larger the backspacing the more rubbing you would have because it brings the tire closer to the frame?? thats why people run the spacers
  6. Dec 1, 2009 at 11:08 AM
    The_Hodge
    SC
    stock rims are 5.5" BS. the less the BS, the further it sticks out
  7. Dec 1, 2009 at 11:12 AM
    dylandercole
    Dylan
    gotcha. ok well let me aqsk this then. Which one will be better for running 285s? 4'' or 4.5'' backspacing
  8. Dec 1, 2009 at 12:15 PM
    Artiz
    Artiz This space is in BLANK mode.
    The mojaves should fit just fine. And I think they only come with 4.5" backspacing in the 16"x8" 6on5.5 configuration, and a lot of people run big tires with them.
  9. Dec 1, 2009 at 12:22 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I got the ATX THUG wheels that are 18x9 with a -12mm offset running 285/65-18"s. Not sure what the backspacing is but I only had to do some minor trimming to avoid contact at full-tilt.:cool:
