Atypical wheel bearing symptoms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glennv, Jul 19, 2015.
  1. Jul 19, 2015 at 6:30 PM
    glennv
    glennv [OP] Well-Known Member
    I've had a growl up front for a few months now and getting worse lately. It is constant when going straight and goes away when I turn right. Based on what I've read this would indicate that the passenger side is the bad one but when I changed it out the sound didn't go away. I am certain the sound is coming from the divers side but it defies what is typical. No wiggle in the wheel but with a stethoscope I can hear more noise on the drivers side than I do on the right.
    Anyone have this issue?
  2. Jul 19, 2015 at 6:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Give Bamatoy a ding and buy a new d/s bearing.
  3. Jul 19, 2015 at 7:11 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    With double-row bearings like the Tacoma uses on the front, it depends on whether the inboard or outboard races and rollers are pitted for the noise to diminish in a left or right turn.
  4. Jul 20, 2015 at 7:48 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    I changed out the wrong bearing in my ranger cuz i followed what is supposed to be the normal symptoms too. changed out the other side and that was def the problem.
    Additionally, i helped another member on here a couple weeks ago with the exact same problem- he changed out the wrong side, and after changing the OTHER side it was fixed.
  5. Jul 20, 2015 at 7:51 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Yup sounds like a bearing & if it makes you feel better......once 1 goes bad, the other side won't be far behind it.
  6. Feb 26, 2016 at 9:30 AM
    uscengnr08
    uscengnr08 New Member
    Eric
    Nomad
    2009 TRD Sport DCSB 4X4 MGM
    FX-R 3.0 Bi-Xenon retrofit, URD MAF sensor calibrator, Leer 100XQ Shell, Bedrug carpet liner, FNWheels BFD 18" + Michelin LTX AT2 285/65R18, OME Dakar, Toytec 3" coils, Bilstein 5100, Satoshi Grill mod, slotted front discs
    Hey OP, sorry to revive a long gone thread, but I've been having this exact same issue with a supposedly quiet set of Michelin AT2's. It's independent of which wheel is mounted, and 2 alignments did not change the 'growl'. Did you ever replace the driver side bearing and did that fix the problem?
