Audible click under hood with heat on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JARStacoma, Oct 31, 2017.
  1. Oct 31, 2017 at 1:01 PM
    JARStacoma
    JARStacoma [OP] Well-Known Member
    Alaska
    17' inferno TRD OR MT
    I'm sure this is normal but an observation none the less. Temps are dropping so have been running my heater while wRming up vehicle. With heater on I can here a loud "click" under the hood. The timing is variable not at all same interval? Just curious.
  2. Oct 31, 2017 at 1:24 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Video?
  3. Oct 31, 2017 at 1:29 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    If you have the mode set to defrost it's your AC compressor kicking on most likely...
    over60, Toyko Joe and Lucifer1 like this.
  4. Oct 31, 2017 at 1:38 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    I agree with Styx586
    over60 likes this.
  5. Oct 31, 2017 at 1:41 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Yup...A/C cutting in..!!
  6. Oct 31, 2017 at 1:42 PM
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
    This.
  7. Oct 31, 2017 at 2:41 PM
    JARStacoma
    Alaska
    Thanx. Will try to duplicate. It is set on defrost so that makes sense. It def goes away when I turn heat off. Didn't realize a/c comp. ran in defrost. This would explain the back in forth idling while in warm up and defrost on?
    over60 likes this.
  8. Oct 31, 2017 at 3:04 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Correct
    over60 likes this.
  9. Oct 31, 2017 at 3:07 PM
    JARStacoma
    Alaska
    Thanks everyone for your input. Just continuing to learn about all the clicks and noises so I know when something is not right. Thanks for the knowledge!
    over60 and Pittrider like this.
