Audible click when letting off the brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GDSeaMonster, Feb 2, 2024.
  1. Feb 2, 2024 at 7:08 AM
    GDSeaMonster
    GDSeaMonster [OP] New Member
    2018 4x4 SR5 with 65,000 miles. Automatic. 6 cylinder.
    I can sometimes here a single click noise coming from the front of the truck when I have my windows down and I'm near a wall. It seems to occur when I'm slow rolling between first and second gear or letting off the brakes to accelerate when already moving. I cannot hear it in the cab with the windows rolled up, and I cannot feel it through the truck. It sounds similar to when I shift into 4WD High. My truck has been maintained perfectly. All fluids in the transfer case, differentials, and transmission have plenty of life left in them. Is this just the sound of the transmission shifting down? Anyone else experience this?
  2. Feb 2, 2024 at 8:33 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    It’s probably either pad shift or a front axle spline clicking.
    GDSeaMonster[OP] likes this.
  3. Feb 2, 2024 at 8:47 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    If it is a single metallic "clack" noise it is probably the front pads shifting around, pretty common.
    SR-71A and GDSeaMonster[OP] like this.
  4. Feb 2, 2024 at 9:27 AM
    Gord0
    Gord0 Well-Known Member
    Pad shift, they all do it eventually…
    I noticed it just yesterday on my ‘21.
    My old GX has done it for years, not sure that there’s any way to stop it.
  5. Feb 2, 2024 at 9:57 AM
    BlackCat81
    2023 Ice Cap TRD OR
    My GX does it too. And the Tacoma uses the same style calipers.
  6. Feb 2, 2024 at 10:12 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW..
  7. Feb 2, 2024 at 2:26 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Supposedly getting a second pair of pad spreader springs will stop that. I've been meaning to do it for 85,000mi, still haven't lol
    Edit: @Gord0 see about getting the V shaped springs as found in hardware packs, the trucks supposedly have one on each side and a second is said to spread the pads equally. They're really to reduce drag and are only strong enough to pull the pad away from the rotor face in that regard. They're like a double-sized paperclip.
    If I remember to do it, I'll grab some this weekend, clean and grease stuff and report back.
  8. Feb 2, 2024 at 3:04 PM
    Gord0
    Ive been running two of the springs per side for some time and I’ve refreshed them a few times. No help with the pad shift or clicking sounds…
  9. Feb 2, 2024 at 3:05 PM
    BlackCat81
    2023 Ice Cap TRD OR
    It doesn’t work. I have 4 total on my Lexus. Still does it.
  10. Feb 2, 2024 at 3:26 PM
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
  11. Feb 2, 2024 at 4:37 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, pad shift as mentioned. Mine had it
    Pull pins, pads, remove shims. Clean all with brake cleaner. Grease back of pad, bothsides of shims. Wire brush pins, and then reinstall. Buy quality brakes grease.
    Doobfucious and GDSeaMonster[OP] like this.
  12. Feb 3, 2024 at 7:12 AM
    GDSeaMonster
    Thank you for the responses, everyone.
    I did get the chance to get my truck close to a building and test the pad shift theory. I simply started moving forward and applied the brakes until I stopped. I then put the truck in reverse and started rolling backwards. I didn't hear the click until I applied the brakes again. So, I'm almost certain that all of you are correct. Thanks again!
    Doobfucious and RustyGreen like this.
  13. Feb 3, 2024 at 10:16 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I would wonder if mine stopped making the noise.
    I think Toyota designed it that way so you have an audible check that the brakes aren't dragging. ;):laugh:
