Audio cutting out intermittently
Discussion in 'Audio & Video' started by RTweet, Sep 2, 2022.
  1. Mar 10, 2023 at 6:49 PM
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    Will do.. Thanks..
    soundman98 likes this.
  2. Mar 10, 2023 at 9:20 PM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    i had the exact same issue with mine, recorded it showed it to the dealership couldnt figure out why. they said it would be 2k for a replacement said screw that and went the aftermarket route. couldn't be happier. Carplay is such a refreshing feature
  3. Mar 11, 2023 at 8:31 PM
    Hiker46
    Tim
    Colorado
    OVRLND Camper.
    Finally got some sun here and removed the door panel while the speaker was malfunctioning. I took a home speaker and wires, touched the door speaker terminals and had music. So I think the signal from the head unit is good. I reset the door speaker terminals and connector and the door speaker was working. I think there may have been some corrosion in the connections. Before remounting the speaker cut out again and there was very faint music coming out of it, but the home speaker worked. I redid the connections and the door speaker was working again. Remounted the door speaker and reinstalled the door panel all the while the speaker was working OK. If it cuts out again I'll replace the speaker. Fingers crossed.
  4. Mar 12, 2023 at 7:04 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    can also apply some anti-corrosion, and/or bend the terminals slightly to make a better contact within the connector.
  5. Mar 17, 2023 at 9:17 AM
    kyhillbilly55
    kyhillbilly55 Active Member
    Tacoma 2022 TRD sport
    Well that explains alot....my 2022 tacoma with non-jbl HU and my Audio Control D-4.800 processor/amp with GTO turned on........it will work well for a while and then usually after a cold night i will get in it and start it up and bang ....no audio....I removed the HU hoping to find a loose connector, no dice. Then once i disconnect the speakers and reconnect to the radio, start the truck up ...it works. I guess it resets the voltage trip and works for a while.
    I will be redoing it now and turning off GTO and run a wire to a 12vdc keyed device like the cigarette lighter or something to kick on the Audio Control amp.
  6. Apr 1, 2023 at 12:46 PM
    6ixty8ightWhiskey
    6ixty8ightWhiskey New Member
    2016 Gray Tacoma base model double cab
    Destin, where is the Radio Detect button? It's probably a dumb question but I can't seem to find it.
  7. Apr 1, 2023 at 3:48 PM
    SteveKayak
    SteveKayak Active Member
    2021 DCLB Off Road
    I had an issue with my tweeters and mids cutting out. The problem ended up being the cheap monoprice rca cables. I bought some better ones and haven’t had a problem since.
  8. Jun 16, 2023 at 8:05 AM
    Qbrute
    Qbrute Well-Known Member
    Ontario, Canada
    2023 Black Tacoma OR SB
    I'm having some issues with my truck similar to this. It's a 2023 stock system, and the audio is cutting out through all speakers. I'm connected by usb and playing through bluetooth.
    It doesn't seem to matter if i'm using android auto or the standard media player. I'm using spotify but it doesn't seem to matter if it is locally downloaded to my phone or streaming.
    I couldn't find any relevant settings in the console. Any recommendations on how to troubleshoot this?
  9. Jun 16, 2023 at 6:33 PM
    soundman98
    NW Indiana
    have you tried rebooting your phone?
  10. Jun 19, 2023 at 3:37 PM
    Qbrute
    Ontario, Canada
    yeah, it's still happening about once per song.
  11. Jun 20, 2023 at 5:45 PM
    soundman98
    NW Indiana
    do you have another bluetooth device to connect/try? does it happen only with your phone?
  12. Sep 23, 2023 at 7:19 AM
    Qbrute
    Ontario, Canada
    in case anyone else finds this thread and gives a care, i talked to the dealer while scheduling my first maintenance and was able to determine this is happening with projection mode only. bluetooth is fine. other devices make no difference. on official toyota sites, i could find suggestions to find a 'toyota certified usb cable' but the parts dept has no idea what that is. could be a faulty usb port, the cabling or the unit itself. either way its under warranty so i will stop complaining on the boards.
    Stevie17 and soundman98 like this.
  13. Sep 23, 2023 at 6:57 PM
    soundman98
    NW Indiana
    generally an 'official certified cable' is going to involve purchasing the cable from your official cell phone networks store, usually with a notation on it that it's 'certified to work on "____" network(despite cables not being tied to networks). i haven't seen a car-brand specific notation like that before, as most oem's are quick to offload that to responsibility to the phone manufacturer. no vehicle oem makes certified cables to my knowledge.
    from my experience in car computers and extremely custom audio routing, audio interrupt issues are generally software error problems (incorrect settings, jumping between programs, or faulty drivers), and rarely ever a hardware issue like a cable, or connection.
    cabling or connection issues are generally repeatable--ie: "when i hold the cable end at 90-degrees to the connector to the right, it cuts out, but holding it 90 degrees to the left, up, down, the audio doesn't cut out".
    Qbrute[QUOTED] and Stevie17 like this.
  14. Sep 30, 2023 at 2:03 PM
    Qbrute
    Ontario, Canada
    I appreciate you sharing your experience @soundman98
    I took my truck in for its first service and talked to the technicians about this, they mentioned this happened last year with the Rav4s and there's typically an update to the system. He agreed with your perspective, probably not hardware. i'll just be patient for now
  15. Jan 26, 2024 at 10:30 AM
    #35
    Qbrute
    Ontario, Canada
    For anyone who is interested, I have an update on this.
    I kept asking the dealer if there are any software updates for the head unit and I was getting nowhere. I shared some dashcam clips with the dealer that captured the music and GPS audio dropping and today Toyota agreed to replace the head unit.
    It took a long time to get someone at the dealer who would listen and have the patience to help, but finally making some progress.
    soundman98 and Stevie17 like this.
  16. Jun 28, 2025 at 9:33 AM
    #36
    Rbeezy3636
    Rbeezy3636 Active Member
    15' Magnetic Grey SR5 4x4
    Color matched grille, KandN
    Did anyone find the solution for the intermittent audio issue?
    It just started happening with my 2015. It happens with CD, radio, and Bluetooth. I installed infinity components all around. Seems like a wiring issue to me or something. I just wanted to check before I start tearing the doors off.
    Thanks
  17. Jul 5, 2025 at 8:55 AM
    #37
    Rbeezy3636
    update to my situation. A little backstory first.
    I had Morimoto fog lights installed in the first year of ownership by some random shop. They lasted about 2years before the corrosion in IL got them.
    then I had 2020 4Runner OEM’s installed by 4wheel parts. They said “hey the last shop wired the fog lights wrong. Do you want us to fix it.” Yes. they’ve lasted about 4yrs. Until now
    as I was diagnosing the intermittent radio issue. I found some random fuse soldered to the main ignition wiring. So I immediately disconnected the fog lights and removed the fuse pigtail (the inline fuse for the fog lights is still on). I also noticed the 30a fuse under the hood was missing completely and installed a new one. Now the radio is working fine.
