Audio Hiss
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Terakin7, Mar 29, 2023.
  1. Mar 29, 2023 at 6:39 AM
    Terakin7
    Terakin7 [OP] New Member
    JD
    Hey Folks,
    I just bought my first Tacoma (2019) and when I turn on the audio I get a loud hiss and doesn't sound right (very trebley(?), "s" sounds really cut through). It gets better when I power off the audio but there is still a little bit. Looks like the factory speakers have been replaced with Kickers. Any ideas of where to start diagnosing the issue?
    Thanks,
    JD
  2. Mar 29, 2023 at 8:03 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Is there an amp somewhere.
  3. Mar 29, 2023 at 8:25 AM
    Terakin7
    JD
    It doesn't look like it. After doing a little more digging I think that may be the issue. So I am assuming I need to add an amp or replace the head unit?
  4. Mar 29, 2023 at 8:35 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You might have to pull the HU to see if there's a mini-amp hidden behind. Its also a good opportunity to check the condition of the wires and if/how they were tapped.
    And it also depends on the speakers. The common types of kickers, when combined with some dash tweeters, can get shouty unless mitigated with DSP or EQ. I just until recently ran a Kicker CS/ Kicker tweet combo. I was happy with it after applying some tricks to it. But I had to apply some tricks.
    Jesse H likes this.
  5. Mar 29, 2023 at 8:38 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Definitely pull the headunit to check behind it. My Alpine Power Pack (mini amp) gives a very faint hiss that's only noticeable when the truck isn't running and the music is off.
  6. Mar 29, 2023 at 8:40 AM
    MannyTheAudioGuy
    MannyTheAudioGuy Well-Known Member
    Emmanuel
    Napa
    2017 Tacoma TRD Sport
    I have put in Racesport gen3 leds I'm the process of doing a custom audio overhaul which will include Hybrid audio unity 6x9 mid bass, unity 3 inch mid driver in the dash and fiberglassing tweets in pilar soundeading all the doors, floors, and headliner and I will be using a helix processor to retain the factory radio and as far as subs I might make custom brackets to move rear seat foward a few inches to get a full size sub in there or I might just go with a pair of jl tw5 or tw3 and it will all be powered by jl audio HD amps or I might try out the new hybrid amps
    Is it a consistent hiss? Or does it change tone with the trucks rpm’s? Regardless it sounds like the previous owner has an amp somewhere in there and is overdriving the inputs. Most Toyota radios have a high floor noise meaning that that there is a constant hiss and the higher the gains in the amp the more noticeable it will be so I would try to find the amp and bring the gains down a bit to make it less noticeable
  7. Mar 29, 2023 at 8:57 AM
    Terakin7
    JD
    Thanks for all the replies! I will open it up this weekend and see what I can find.
