Audio (horn) for locking doors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteDog, Jul 18, 2016.
  1. Jul 18, 2016 at 6:20 AM
    WhiteDog
    WhiteDog [OP] King of the Brittanys
    Brian
    Central Indiana
    Can the Taco be programmed to honk the horn when locking/unlocking the doors using the key fob? Now my lights just flash.
    Is there a list somewhere of customer programmable choices for my truck?
  2. Jul 18, 2016 at 6:27 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    HI whitedog, I'm sure that if the lights flash you can pick up a feed for the horn to also chirp. My truck has a remote starter and it chirps when the doors lock.
  3. Jul 18, 2016 at 6:37 AM
    Taco Hunter
    Taco Hunter Well-Known Member
    Hunter
    Triad, NC
    09' Tacoma 2.7l AccessCab 4x4
    Old Steelies to Trd 16'' Matte Black with Cooper ATX3 tires Mech to Electric (Very large but super silent) Single Fan Throttle body coolant bypass + Port and Polish LED Fog lights with custom fabricated mounting 2012 headlight assembly K&N Drop In Intake StopTech Drilled Rotors with EBC Greenstuff Pads StopTech Front + Rear Stainless Steel Brake lines Old Fabric to leather swap on doors 20% Window Tint LCE Long tube headers with Milltek resonator and Magnaflow 12586 muffler WeatherTek In-Channel Deflectors Fox Racing 2.0 Coilovers with Fox 2.0 IFP in the rear Total Chaos UCA's Whiteline Lateral Locks Hellwig Rear Sway Bar Energy Suspension Poly Bushings: Sway Bar, Cab, Rear Leaf Spring
    No need for all of that! There is a way you turn the ignition on and hold certain buttons down that brings up options on your odometer and one of those options is the chine for locking/unlocking your truck. I am on my phone atm but if you search you should be able to find it. Try "Alarm chime" idk. I'll look when I get home later if you can't find it. What year is your truck?
  4. Jul 18, 2016 at 6:43 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Someone may have unplugged the "chirper" ... lift hood ... right of centerline ... little 1" square box ... unplugged nearby ... I have unplugged this on two trucks now ... lights still flash ... just a thought.
  5. Jul 18, 2016 at 8:32 AM
    Taco Hunter
    Hunter
    Triad, NC
    Easier way to find out is if it honks (Same horn). Good idea to check though
  6. Jul 18, 2016 at 9:36 AM
    WhiteDog
    Brian
    Central Indiana
    My truck is 2006. I'll look for the unplugged chipper!
  7. Jul 18, 2016 at 10:18 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I wish mine was louder for times when I am walking away and not looking at the truck.
  8. Jul 18, 2016 at 10:25 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    OEM Piezo buzzer made it's to OEM keyless from 2009-2015. OP would have to wire a piggyback keyless entry to adapt to horn to give an audible lock confirmation.
  9. Jul 19, 2016 at 1:05 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This enables or disables the chirp. Like a toggle switch:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/46824-quieting-lock-unlock-beep.html
    Step one: Open the drivers door and insert the key into the ignition
    Step two: Remove the key from the ignition and, within 5 seconds,
    reinsert the key back into the ignition and switch to the on position. Do not start the engine.
    Step three: After 10 seconds, the system enters the answer-back mode
    Step four: Within 10 of the answer-back beep the switching mode is started, press the remote twice and the system will turn off or on based upon which the system is set.
  10. Jul 19, 2016 at 1:23 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    This^^^^ I unplugged mine after growing annoyed with all the beep beeps when unlocking all four doors with the fob
