Audio install on stock radio?
Discussion in 'Audio & Video' started by tacoany1?, Dec 30, 2008.
  1. Dec 30, 2008 at 6:25 PM
    tacoany1?
    tacoany1? [OP] Well-Known Member
    Baton rouge LA
    05 lb dc 4x4 Tacoma Silver Streak
    3" lift, ebachi coils, 5100's with top plate spacer and differential drop.
    I plan to install my jl amp and solo baric sub in my 2009 std cab prerunner. Does anyone know the process for connecting it too the stock radio? I dont want to use an aftermarket radio and just wondering if anyone has done this? Thanks
  2. Dec 30, 2008 at 7:16 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    what jl audio amp are u using. if its a slash series i think jl audio sells special rca input harnesses for that amp. that's the cheapest way to do it. if you want the best sound you need a processor that strips the factory eq. there is the jl audio cleansweep, rockford fosgate 3sixty and the mtx re-q. my preference is in the order listed, with the jl cleansweep being the best and easist to install.
    http://www.crutchfield.com/p_136441DSP/JL-Audio-CL441dsp-CleanSweep.html?search=cleansweep&tp=6870
    http://www.crutchfield.com/p_236REQ/MTX-re-Q.html?search=re-q&tp=6870
    http://www.crutchfield.com/p_5753SIXTY2/Rockford-Fosgate-3SIXTY-2.html?search=3sixty&tp=6870
  3. Dec 31, 2008 at 7:16 AM
    tacoany1?
    Baton rouge LA
    Excellent info, do i hook my amp to the cleansweep and it hooks to the factory stereo? Great info again
  4. Dec 31, 2008 at 10:20 AM
    itsmyturn
    Victorville, CA
    yeah the cleansweep connects to factory headunit speaker outputs. most people mount it somewhere in the dash or glove box. then the rca outputs connect to your amp. i too am thinking of going this route but i favor the new alpine ipod only headunits. glad this helps.
