Audio Nightmare! Need Some Help
Discussion in 'Audio & Video' started by *TacoAesthetic*, Dec 3, 2017.
  1. Dec 4, 2017 at 6:15 AM
    *TacoAesthetic*
    *TacoAesthetic* [OP] Well-Known Member
    Burlington, Vermont
    2017 Super White TRD Pro
    It does not
  2. Dec 4, 2017 at 6:43 AM
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    I can confirm that the output of the head unit does not have signal level outputs, so you should have had to have some kind of converter on it. I'm no expert, just learned a few things when I was replacing my speakers and that was one of the biggest drawbacks on this unit as it makes it difficult to add aftermarket equipment to it.
  3. Dec 4, 2017 at 11:42 AM
    *TacoAesthetic*
    Burlington, Vermont
    Interesting.. what converter did you end up going with? Is that something I could install?
  4. Dec 4, 2017 at 1:16 PM
    jsey21
  5. Dec 4, 2017 at 7:20 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    this amp has a high low signal capacity i believe meaning you technically should be able to hook the amp up to a signal.
    Theres a few things one can do. Trace the input wires to the source and find out where they are hooked up first
  6. Dec 5, 2017 at 12:49 AM
    licktheenvelope
    licktheenvelope More outdoors please
    B.C
    2017 Cement Grey Tacoma TRD Pro
    I have a TRD Pro and am switching out the speakers in a couple weeks when harnesses and mount for tweeters arrive.
    I was going to ask if you swapped out the tweeters too... I've seen a few videos of guys who changed out all the door speakers but left the stock tweeters in the front dash and apparently they are by far the worst part of the stock system.
    Beyond that (as I understand it) if he isn't using adapters for the replacement tweeters up front he would had had to splice the wiring on new ones (unless you got those Subaru Kicker ones). The front door speakers run in parallel to the tweeters so if a tweeter isn't going the corresponding door speaker won't be going.
    Hard to tell because you need to check all the wiring, etc.
  7. Dec 5, 2017 at 6:21 AM
    jsey21
    Yes, the tweeters are the weak link in the stereo chain. You could probably just change them and be fine w/ the stock system.
    Also, yes, whoever installed your system had to use the correct connector (********* has one) as the tweeters and front door are wired in series. So, you will mess things up if you are going to a component type system if you did NOT run more wires to the door speakers from the tweeters.
    Sounds like you would have to have had them run the wires for each speakers from the new amp, so I would doubt a stereo shop would mess that up, but you never know.
  8. Dec 5, 2017 at 6:31 AM
    azsean
    azsean Well-Known Member
    sean
    HELL ... aka mesa,arizona
    2013 black prerunner trd sport
    gosh.. where do I start, 18x9’s on 275-65 ridge grapplers. Bilsteins, clazzio leather, audio consists of stereo integrity,fosgate power amps,sundown audio, hybrid audio. Plus more...
    it looks like to me that ur gains are all the way up.
  9. Dec 7, 2017 at 3:43 PM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    See if he grabbed the signal from the rear speakers. Before I got my HU I installed a 2ch and front speakers in my truck. Originally grabbed hi level signal from the rear speakers cuz those wires were very accessible. It sounded like dog shit. Rewired and grabbed signal from the front speakers and it sounded way better. The stock HU puts out crap signal to the rear speakers.
  10. Dec 7, 2017 at 5:08 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Your amp should work fine with the stock headunit.
    Not knowing what your entire setup is, I would also suspect it is screwed up because the installer did not know about the front tweeters being wired in series with the front woofers. If the installer simply connected the output (from the Amp) back to the factory speaker wire harness, then your front speakers are not going to work properly.
    I think you are using the stock/OEM headunit (non-JBL), so we need to know a few more things:
    - Are you still using the factory speakers?
    - Do you know if the installer ran new wires or reused the factory speaker wires?
    - Did you get anything else besides the amp and speakers (such as wiring harness adapters)?
    - If so, then what?
    - Someone else asked earlier, but do other speakers sound good and you're just having issues with the crackling tweeter?
  11. Dec 7, 2017 at 6:14 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    I had the stock door speakers removed & replaced w/ Hertz 2 way 6x9 & a separate tweeter in stock location w/ crossover. I didn’t do an amp or sub. I did away with the radio that was in it & went with a Pioneer DVD/CD Bluetooth touchscreen. Sounds amazing!
    FastEddy59 likes this.
  12. Dec 8, 2017 at 7:44 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Sorry for not seeing this sooner but my daughters illness flared up again recently and clinics/doctors have been occupying my time. I did not have a chance to read this entire thread however I will be available for troubleshooting in the evening this weekend or if you let me know the best time to call you I can sometimes call while I am in the parking lot at the clinic.
  13. Dec 8, 2017 at 3:14 PM
    *TacoAesthetic*
    Burlington, Vermont
    Thanks for the reply! I ended up bringing it to another installer who pointed out that the original tech spliced wires pretty goofy and didn't use a recommended plug adapter. He also pointed out that the previous installer broke the clips from the tweeter covers..
  14. Dec 8, 2017 at 3:34 PM
    jsey21
    I think you found your problem. Let us know how it turns out. :thumbsup:
  15. Dec 8, 2017 at 3:37 PM
    #35
    *TacoAesthetic*
    Burlington, Vermont
    New guy put the harness on and said he'll replace the tweeter covers once they get delivered from the dealer.
    Old guy got an ear full and said to just send him the receipts and he'll send a check.
    ToyoDrew likes this.
  16. Dec 9, 2017 at 11:29 PM
    #36
    ToyoDrew
    Texas
    WOW! the tweeters are the easiest thing in the world to change out! lol They must not have removed the A pillar trim first. lol oops
    Glad you got it all sorted out. How does it sound now?
  17. Dec 27, 2017 at 6:31 AM
    #37
    twp
    twp Well-Known Member
    Ky
    2002 trd
    So how is the sound now? Did that fix it?
