Audio setting help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sdshooter, Aug 29, 2016.
  1. Aug 29, 2016 at 9:59 PM
    Sdshooter
    Sdshooter [OP] Well-Known Member
    San Diego
    2017 TRD Off Road 4x4 Quicksand
    Kings on all four Pelfreybilt bumpers Dakar Leafs other crap
    I took my Tacoma to see a drive in movie and my audio would automatically shut off every 20 minutes. The truck engine was off for the duration of the movie. I am sure it's a power saving setting or something of that nature. Does anyone know if this can be changed? I appreciate any help in advance.
  2. Aug 30, 2016 at 5:45 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    I believe I read somewhere that you put it in N with parking brake and then turn the engine off, and it will stay on. not sure though.....I'm sure its somewhere in the tips and tricks thread
  3. Aug 30, 2016 at 6:19 AM
    Sdshooter
    San Diego
    Thanks @mbarbay. I'll give that a shot!
  4. Aug 30, 2016 at 8:23 AM
    jcfergus
    jcfergus Member
    Jim
    Roseville, CA
    2019 TRD Sport Access Cab
    TRD Pro wheels (gray), Snugtop shell
    Any selection other than P will keep it on, but it will still time out after about 20 minutes. I haven't found a setting for it, and suspect there isn't one to prevent the battery from being inadvertently drained.
    sadmrhappy likes this.
  5. Aug 30, 2016 at 9:35 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    From the tips and tricks sticky:
    35. If the engine is running just press Push to Start button in any shift (R-N-D or S)except in P and radio won't go off. (Courtesy of abec)
    36. If you leave the transmission in neutral while parked in ACC mode and pull the hand brake, the radio seems to not have a turn off timer. A user reported over 2 hours of radio time while at a drive-in movie while using this method.
    tomwil, sadmrhappy and Sdshooter[OP] like this.
  6. Aug 30, 2016 at 9:46 AM
    Sdshooter
    San Diego
