Audio Solutions 2016-2019 Plug and Play Remote Starters, 3x and cell for AT
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by jmeitz, Feb 9, 2018.
  1. Feb 13, 2019 at 7:45 PM
    #541
    personalt
    personalt Well-Known Member
    Just a heads up to anyone looking to do this remote start.. I bought a kit from Jeremie and couldn't be happier with the remote starter and with the service I got.. The remote start itself was super easy to 'install'. you just plug in a few harnesses. Less then 5 minutes to get the brain installed.
    I have the most basic SR which didnt come with keyless entry so I ordered his package with a 4 button two way remote. I had a little trouble programming the remote(though it is actually very easy, I must have fat fingered the buttons on the remote the first time through and I had to reset the remote to start over). Jeremie messaged me back within a few minutes of me messaging him and we were on the phone a few minutes later. This was really helpful
    And the price was hard to beat.. The package for trucks without keyless is always a bit more as you need to buy key fob add-on but his price was a good $50 cheaper then I had seen elsewhere for the same kit. if you are on the fence got for it.....
    jmeitz[OP] likes this.
  2. Feb 14, 2019 at 2:08 PM
    #542
    jmeitz
    jmeitz [OP] Audio Solutions
    Jeremie
    St. Louis, MO
    2016 Tacoma trd sport
    Remote Start Lift Stereo Leather LED lights
    I have one push to start 3x kit ready to ship. Who wants it. PM me.
    Cl4aub likes this.
  3. Feb 14, 2019 at 2:49 PM
    #543
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    nj near philly, what's up?
  4. Feb 17, 2019 at 11:32 AM
    #544
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    If you don’t have this kit jump on it. It’s great.
    FYI. I removed the metal T30 bolt from the door sensors on the rear doors and passenger front door. Now I can open all those doors while the engine is still running. No codes. I get all my stuff situated, including putting my kids in their car seats then pop in the driver seat and restart the truck. Easy money.
    Also, if you turn off the Auto lock timer under vehicle settings the doors don’t relock as you’re getting everyone in. Plus the overhead lights still all work.
  5. Feb 17, 2019 at 3:45 PM
    #545
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    You can accidentally now lock your fob in the vehicle, be careful about this. And the dome-lights all work as in come on and off as they’re supposed to? With out the sensors working as they should, all logic depending on this condition will not function as your vehicle now thinks the doors are always close.
    If you ever get the smart phone control module, your door status will always show locked, you’ll never truly know if it’s unlocked which means you’ll have to be redundant when in doubt and click “lock” in the app again...be careful as shifting in gear warnings also depend on this sensor. There might be more, test your auto lights when done driving if they turn off and after how long, they should technically...what about when a door doesn’t shut completely on a side you don’t see, does the vehicle stop let you lock as opposed to complaining?
    So are you tapping the brake then restarting or pushing the ignition PTS once, then twice to restart?
  6. Feb 17, 2019 at 3:56 PM
    #546
    uploadadventure
    Dixon, Mo
    @N2DesignsInc you made a good catch about the lock feature with the smart fob.
    When I said turn off the “unlock” feature, I absolutely meant lock. You can turn off the auto lock. (Get 4 options; off, 30, 90, 120 seconds) I’m sure you could do the 120 seconds if you wanted.
    Second, I found you have to keep the driver door bolt and sensor all together. Unless you want to installed some switch or something, I’d rather just keep the bolt in the door as I found out that the headlights do not turn off on their own when the stalk switch turned to the auto section. (It does this cause the doors never opened, truck knows, as you know) The driver door sensor is the key to the whole system. Truck still shuts off when I open the door. With the bolt out of the driver door you still have to shut the truck off and turn it on, so might as well as keep the sensor complete.
    The other three doors don't matter per say. Also, when you walk up to the truck to unlock, your map and dome lights turn on for a user specified amount of time.
  7. Feb 19, 2019 at 12:42 PM
    #547
    taco_chaser
    taco_chaser Well-Known Member
    Alberta, CA
    '13 black TRD Sport
    285's
    Hey, do you have one for 2nd gen? (2013 sport) Sorry if I missed this in here, can't read it all.
  8. Feb 19, 2019 at 12:43 PM
    #548
    jmeitz
    Jeremie
    St. Louis, MO
    Sorry I do not.
  9. Feb 19, 2019 at 12:44 PM
    #549
    taco_chaser
    Alberta, CA
    '13 black TRD Sport
    285's
    Ok, tks. I'll look around.
  10. Feb 20, 2019 at 8:34 AM
    #550
    Taco_Coma
    South NJ
    2018 DCSB SR5
    Is it possible to Extend the run time while the truck is running? My old car if you wanted to have the car run longer you just pushed the start button again and the timer reset. Does this one too? I have the cell module too
  11. Feb 20, 2019 at 8:38 AM
    #551
    jmeitz
    Jeremie
    St. Louis, MO
    Unfortunately not, 15min is the longest for the evo one.
  12. Feb 20, 2019 at 8:40 AM
    #552
    Taco_Coma
    South NJ
    2018 DCSB SR5
    Thanks for the quick response. Trying to plan my exit from work with all this snow we’re getting here
  13. Feb 20, 2019 at 9:00 AM
    #553
    imovelives
    imovelives Well-Known Member
    Erwin
    San Diego
    18 Tacoma TRD off-road 4x4
    Flowmaster, Pace Edwards Jackrabbit, bedrug, pop n lock TAILGATE lock Kuat Bikerack NV, PioneerNDBC8 front camera, pioneer avh-w4400nex head unit, DWG D10 17x9, good year wrangler ultra terrain AT Kicker speakers font/back Max Modular KBvoodo 10 inch rack (linger on short bed) Freespirit high country medium RTT Pedal Commander
    They fix the mobile app yet?
  14. Feb 20, 2019 at 9:11 AM
    #554
    jmeitz
    Jeremie
    St. Louis, MO
    No, suppose to have it to me this week to test the beta OTA. They said on their side it fixed the issue, but want a real world person to test it. As soon as I know something will definitely post.
    shawn3210 likes this.
  15. Feb 20, 2019 at 9:13 AM
    #555
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    What is wrong with the app? Mine has been working pretty good since the last update a week ago or so.
  16. Feb 20, 2019 at 9:16 AM
    #556
    jmeitz
    Jeremie
    St. Louis, MO
    It doesn’t impact everyone. Has to do with network issues and the cell module locking up when the vehicle moves and having to be rebooted.
    shawn3210 and TiHo[QUOTED] like this.
  17. Feb 20, 2019 at 9:17 AM
    #557
    TiHo
    2018 TRD Sport
    Dang I hoped they were fixing the timer on it. Mine says 30 minutes when I start my truck but it only actually runs for 15. 15 is fine just wish the app reflected that lol.
  18. Feb 20, 2019 at 9:18 AM
    #558
    jmeitz
    Jeremie
    St. Louis, MO
    Agree, they fixed it one time and now it’s back to 30.
  19. Feb 20, 2019 at 4:48 PM
    #559
    jmeitz
    Jeremie
    St. Louis, MO
    I have an evo all with 4g module ready to ship out. Who wants to be customer #200. PM me.
    N2DesignsInc likes this.
  20. Feb 21, 2019 at 7:20 AM
    #560
    jmeitz
    Jeremie
    St. Louis, MO
    SOLD
    uploadadventure likes this.
