Audio Upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Romanicko, Nov 4, 2023.
  1. Nov 4, 2023 at 11:55 AM
    Romanicko
    Romanicko [OP] New Member
    Hi Peeps,
    I have a 2019 TRD Sport that came with the dreaded JBL audio system I would like to upgrade on a budget.
    I have some components from my old car sitting in my garage I would like to use, which are 2x Kenwood excelon KFC-XW120 4 ohm 12'' subs and a Kenwood x501-1 1000w amp. I am planning to have the subs sitting on the rear passenger side drop down seats for easy removal if the space is needed.
    Now for the main part, I would like to remove the current JBL system completely, including the head unit so I can use Android auto integration, without losing any factory parameters. I am looking to keep the build <$800 for 6 speakers, head unit (probably wired android auto due to cost), wiring etc.
    Has anyone done anything similar, looking for guides and suggestions on components and install?
  2. Nov 4, 2023 at 12:24 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    which factory parameters?
  3. Nov 4, 2023 at 12:30 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Holy shit 2x 12” subs in this tiny cab… is going to be quite a thump.
    imo that budget is too low… quality parts cost a bit more. Also the 12” subs won’t fit behind there unless you start cutting the seats etc or get some really shallow mount option
  4. Nov 4, 2023 at 2:15 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    For android auto, you can always replace your amp and head unit to 2020 or newer,
    Check out this post here for speaker upgrades,
  5. Nov 8, 2023 at 8:53 PM
    Romanicko
    Vehicle settings that you currently control through the head unit.
  6. Nov 8, 2023 at 8:59 PM
    Romanicko
    I'm Literally going to have them laying down strapped on the folded flat back seats, already sized. Yeah, with Black Friday coming up, hoping to get some savings. Will probably gather parts to change out the head unit and door speakers first, and then add the sub and aftermarket amp to connect it all around Christmas.
  7. Nov 8, 2023 at 9:09 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    First off... good luck getting 2 12" subs back there... I only squeezed a shallow mount 10" back there because there wasn't enough air space for anything bigger.
    As for losing factory integration with the radio... anything that is adjustable... you will lose easy access to those adjustments but they are still available through Techstream.
    I have installed a Kenwood DMX1057XR head unit, Kicker speakers in the 6 factory locations and a Cerwin Vega shallow mount 10" in self made fibreglass box. My system was not a JBL though. Just the Entune 2 system... so I only had to wire up the sub and amp. I used the factory speaker harness.
    With the JBL, you may have to run speaker wires because your system should have an amplifier behind the back seat. So the wiring goes there then to the speakers.
    soundman98 likes this.
  8. Nov 9, 2023 at 5:51 AM
    Mtbkrguy
    Mtbkrguy Well-Known Member
    2016 Tacoma TRD Sport 4x4 Double-cab
    Not true... There are headunits out there that still maintain full integration with the factory settings. I have the Alpine ilx-507 with the Maestro from Trail Grid Pro. It maintains all steering wheel controls and has all the settings that were controlled from within the factory unit, like Door locks, headlights, etc. Plus has a million gauges that display that the factory unit didn't have like Air fuel ratio, Exhaust temp, intake temp, etc. I love this unit and Trail grid pro makes it completely plug and play.
    https://trailgridpro.com/products/alpine-ilx-507-plug-play-bundle-16-23-tacoma
    1Crusader and Sweets like this.
  9. Nov 9, 2023 at 4:20 PM
    soundman98
    NW Indiana
    there are a few units that support it, but imo, it severely limits your options.
    imo, it's better to consider either 'setting-and-forgetting' those add-on settings pages, or consider something like techstream or carista bluetooth dongles to do external changes to those settings as needed. but you really shouldn't need to be tinkering with most of those settings that often anyways.
  10. Nov 9, 2023 at 4:27 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
  11. Nov 9, 2023 at 4:35 PM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
