Austin Area TW Chapter (all gens welcome, even T4Rs; heck, just make it a Toyota and we're good)
Discussion in 'Texas' started by CaptAmerica, Jan 18, 2016.
  1. Jan 11, 2017 at 9:56 AM
    #3821
    medjah
    medjah Volleyballing
    Blake
    Austin, TX
    09 Barcelona Red DCSB SR5 TRD OR
    OME 887 Springs OME 90000 Shocks OME Dakar Light Duty Leafs Wheelers SuperBump Bumpstops w/ u-bolt flip Sway Bar relocate Red Brake Lines Ultimate Headlight Upgrade Airflow Snorkel Rear diff breather mod CMC AtTheHelm Bed Stiffeners AtTheHelm Front Rail Chock System Hood Struts
    Thanks for the info. That CB radio is a bit more than I was expecting. Everything seems good. I like the Relentless hood (passenger) mount.
    http://www.relentlessfabrication.com/products/05-tacoma-hood-hinge-cb-aux-mount?variant=6137200900
    If I go with that I shouldn't need much coax right? What spring rate for this mounting location?
    Where should I mount the radio itself?
    I park in a garage with an 8ft ceiling. What length antenna should I get?
    I appreciate any and all input!
    ChadsPride likes this.
  2. Jan 11, 2017 at 10:50 AM
    #3822
    wagerhope
    wagerhope 2000 Landcruiser
    Wayne
    ATX
    2000 Landcruiser
    You can grab any CB radio- that one is the one I went with, and it's out of the way. You wouldn't need 18' of coax if you're hood mounting the antenna. You may need to go with the sideways joint coax there instead of the regular/straight joint.
    I know @tacopromatt mounted his CB in the glovebox. Mine is "mounted" (a/k/a crammed) by the fuse box near the driver's left knee. I take out that little coin tray thing and mount up the handheld radio when I go wheeling. Some folks mount it below the climate controls, leaving just a little spot to plug the handheld portion into.
    8' ceiling means you probably don't want a 4' antenna unless you want to tie it off to a roof rack while not in use. (If you're tying it off, get a medium duty spring so you have some flex.) 2' should be fine, as that'll barely clear the cab.
    You can also just go battery powered handheld for ease of use and "installation."
    medjah[QUOTED] and ChadsPride like this.
  3. Jan 11, 2017 at 11:03 AM
    #3823
    sarsaparilla
    sarsaparilla Well-Known Member
    Tyler
    Austin, TX
    2014 DCSB 4x4 Super White II - Texas Edition
    Radio Operator: KG5SAI
    I just redid my CB set up and provided @ChadsPride with some input recently.
    I run the CBI offroad ditch bracket for my antenna mount and use the fire wire coax cable. The fire wire uses a round inline mount because with ditch brackets there is very little room to accommodate a 90. It will likely hit the windshield which mine did before i swapped it out.
    Like @wagerhope said you can get any CB its just a matter of where you want to put it and how much space you have. Wallmart stocks one that fits in the center console quite nicely but its a bit of a pain to use on the trail when its in there because you have to leave the console open. There are options to alleviate this however. With my new set up I just mounted it on the passenger side of the console. (you can check my build thread to see pics of both my set ups. https://www.tacomaworld.com/threads/sarsaparillas-dcsb-4wd-build.429665/ )
    The installation is pretty easy, but im sure any one of us would be willing to help you out when you get your kit together.
    As far as antenna length goes it really depends where you mount it. If your mounting on the hood a 3' fire stick will work and is only slightly taller than the stock antenna. But it should be taller than the roof of the truck, and generally taller is better. I ran a 4' firestick until i lifted my truck 6" and couldn't park in parking garages with it any longer and now i use the 3' and it works just fine.
  4. Jan 11, 2017 at 11:09 AM
    #3824
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    CB's FS
    http://austin.craigslist.org/tld/5954073520.html
  5. Jan 11, 2017 at 11:10 AM
    #3825
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Jan 11, 2017 at 11:11 AM
    #3826
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    They may be older, but those are solid units
    ChadsPride[QUOTED] likes this.
  7. Jan 11, 2017 at 11:11 AM
    #3827
    ChadsPride
    You tha man!
  8. Jan 11, 2017 at 11:18 AM
    #3828
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    I had a Cobra 75XST in my 07 that was installed in the glovebox, with the main unit mounted under the dash on the passenger side.
    In my new truck, I have the same CB with the unit mounted under the dash on the driver side, and the connector installed in a blank switch.
    @wagerhope listed out everything needed. I will have an SWR meter with me on the weekend of the 28th for tuning needs.
    If you don't want to go through the trouble of installing anything, you could pick one of these up: https://www.amazon.com/gp/product/B00N43KM5S/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    I just got one to use when spotting or for anybody riding with us that doesn't yet have a radio.
  9. Jan 11, 2017 at 11:24 AM
    #3829
    Spansfelder
    Spansfelder Well-Known Member
    Austin, TX / Germany
    05 4WD
    THAT is exactly what I did actually!
    wagerhope likes this.
  10. Jan 11, 2017 at 11:46 AM
    #3830
    sarsaparilla
    Tyler
    Austin, TX
    Even a lot of brand new ones look exactly the same
  11. Jan 11, 2017 at 11:48 AM
    #3831
    ChadsPride
    Shows you how much I know lmao :bananadead:
  12. Jan 11, 2017 at 1:12 PM
    #3832
    Spansfelder
    05 4WD
    May I introduce, the beauty and the beast:
    Pick which one is which :D
  13. Jan 11, 2017 at 1:21 PM
    #3833
    ChadsPride
    Very nice man!!!
  14. Jan 11, 2017 at 2:03 PM
    #3834
    exportexp
    exportexp Well-Known Member
    Fred
    2013 Taco 4x4 - TTC#069
    Little here and there & ChadsPride Likes This Sticker
    Looking for thoughts.
    I'm working on a bed rack to help carry camping stuff. No future planes for a RTT at this time.
    I keeping changing my mind on full lengthish (4' 6") or just 3'.
    Help me make up my mind.
  15. Jan 11, 2017 at 2:08 PM
    #3835
    ChadsPride
    I like that height right there the best.
    And something tells me you will be getting an RTT before too long lol
  16. Jan 11, 2017 at 2:10 PM
    #3836
    sarsaparilla
    Tyler
    Austin, TX
    the beauty is on the right!
  17. Jan 11, 2017 at 2:11 PM
    #3837
    exportexp
    Fred
    I'm asking about the length not how tall.
    RTT may be in the distance future but I'm already planning a trailer and using a poor mans RTT.
  18. Jan 11, 2017 at 2:11 PM
    #3838
    sarsaparilla
    Tyler
    Austin, TX
    Id say it depends on what youre carrying and how you plan to carry it. But the rack looks rad already! Do you plan on mounting a basket or rack like you see mounted to say the roof or on a shell?
  19. Jan 11, 2017 at 2:14 PM
    #3839
    ChadsPride
    Oh right on. It looks a little bit too spread out from the racks I've seen.
    Can you move the bars closer to each other?
  20. Jan 11, 2017 at 2:15 PM
    #3840
    exportexp
    Fred
    No basket at this time. There will be 1"x1" tubing between the risers, but who knows how it will turn out.
