Austin Area TW Chapter (all gens welcome, even T4Rs; heck, just make it a Toyota and we're good)
Discussion in 'Texas' started by CaptAmerica, Jan 18, 2016.
  1. Jul 30, 2018 at 10:39 AM
    neatowhiskey
    neatowhiskey Well-Known Member
    Austin, TX
    2009 TRD Off-Road
    Most of the time I'm at North Austin near the Domain. I do like to explore so I'm all over.
  2. Jul 30, 2018 at 10:39 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    THANK you P-rod!
  3. Jul 30, 2018 at 10:41 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    Prairie Hawk and MattCowsmasher like this.
  4. Jul 30, 2018 at 10:41 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I just squeeze it in feel like a MAN!! But it reality that’s smart.:thumbsup:
  5. Jul 30, 2018 at 11:14 AM
    Sixt8kupe
    Sixt8kupe TTC# 0341
    Patrick
    The Great State of Texas
    '18 DCSB Off-Road 6-speed - BBP
    You could probably get a good 75-100k out of that diff fluid. Coolant and brake fluids as well. The only one I would stay on top of is the transmission fluid.
  6. Jul 30, 2018 at 11:25 AM
    qxrtz4321
    qxrtz4321 Well-Known Member
    Mitch
    Montana / Washington
    Lessons I learned today...
    #1 even if you're in a hurry use a damper on a recovery strap..
    #2 when a septic tank truck gets stuck in your yard, tell them to call a tow truck that it's not your fucking problem.
    #3 when you have a perfectly capable HMMWV use that even if it doesn't have air conditioning because it will pull it right out.
  7. Jul 30, 2018 at 11:27 AM
    Sixt8kupe
    Sixt8kupe TTC# 0341
    Patrick
    I wonder if you can just do the seat belt buckle/unbuckle thing?
  8. Jul 30, 2018 at 11:29 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Sounds reasonable, but it also depends on the amount of time the fluids are in there. Personally, I change/refresh all my fluids every 3 years. I don't put a lot of miles on, but age and other contaminates that make their way in over time come into play. But, end o' de day, it's up to each to decide what makes most sense for them.
  9. Jul 30, 2018 at 11:30 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    @qxrtz4321 Your HMMWV must have been snickering...
  10. Jul 30, 2018 at 11:37 AM
    ChadsPride
    Hows the tranny drain/fill process?
    MattCowsmasher likes this.
  11. Jul 30, 2018 at 11:43 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Expensive I goto dealer for that one. I seen a couple YouTube vids on it I don’t want mess with it.
    ChadsPride[QUOTED] likes this.
  12. Jul 30, 2018 at 11:46 AM
    ChadsPride
    10-4!
  13. Jul 30, 2018 at 11:46 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
  14. Jul 30, 2018 at 11:54 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Easy as pie
  15. Jul 30, 2018 at 12:09 PM
    Sixt8kupe
    Sixt8kupe TTC# 0341
    Patrick
    I don't remember if the tacoma trannies have drain plugs but it is pretty simple as draining, refilling and then checking/adding to get up to the proper level. You could drop the pan (slowly, if there is no drain), pull out the old filter, let it drip for a while, clean up the pan, install new filter, button it up, pour in a few quarts before starting it up, then you'll just have to keep checking/adding fluid until you get to the proper level.
    I'd highly recommend a funnel like this for the transmission:
    https://www.amazon.com/Lisle-17892-Transmission-Drain-Pan/dp/B0002SR6WA
  16. Jul 30, 2018 at 12:30 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Bummer that ain’t gonna buff out.
    BassAckwards likes this.
  17. Jul 30, 2018 at 12:31 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you are talking just a pan drain, it's not bad, but more involved than an oil change or the diff change, but still within the realm of what you can do, just need to be able to read the tranny temp, or set the tranny temp blinker.
    If you are talking about a total change, i.e., flush, definitely even more involved. Personally, I don't see the point in that effort if you are doing a pan drain every 30-50k, but that's just me. Tranny fluid needs additive refresh more than a total change since it's not exposed to all those nasty combustion by-products.
  18. Jul 30, 2018 at 12:32 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    2nd gens have pan drain plugs, and the filter is actually nothing more than a screen over the pickup.
    Sixt8kupe[QUOTED] and ChadsPride like this.
  19. Jul 30, 2018 at 12:42 PM
    qxrtz4321
    Mitch
    got a quote. It's not as bad as I thought. $1,563.50. That's everything including respraying the bedliner and paint
  20. Jul 30, 2018 at 12:46 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Can you claim on insurance possibly? If need be I can “love tap” ya.
    EireBleuTacoma and ChadsPride like this.
