Austin Area TW Chapter (all gens welcome, even T4Rs; heck, just make it a Toyota and we're good)
Discussion in 'Texas' started by CaptAmerica, Jan 18, 2016.
  1. May 18, 2021 at 6:14 AM
    JustinInATX
    JustinInATX Well-Known Member
    Justin
    Texas
    2019 Super White TRD Off-Road 4x4
    Taco Tuesday... name this spot!
  2. May 18, 2021 at 6:20 AM
    GeoTachnical
    GeoTachnical Well-Known Member
    Nick
    Austin, Texas
    16 Taco TRD OR AC 11 Taco SR5 DC SB
    I wonder what you did to piss off Thor? I would invest in a better grounding system as Cap suggested.
    Pyrotech and riz_atx[QUOTED] like this.
  3. May 18, 2021 at 6:22 AM
    CaptAmerica
    CaptAmerica [OP] Asphalt Avenger! TTC#13
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Or put large lightning rods on your neighbor's houses.
    :D
    riz_atx and ryanbitt like this.
  4. May 18, 2021 at 6:32 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    If you can do it, I highly recommend installing storage racks above the garage doors. We have 10' ceilings in the garage, and that is pretty much wasted space, without the racks.
  5. May 18, 2021 at 6:35 AM
    jmdaniel
    Jeff
    Leander, TX
    If you haven't signed a contract with a roofing company, hit me up for a reference. You'll be glad you did.
    riz_atx likes this.
  6. May 18, 2021 at 6:50 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    :pccoffee: Good Morning ATX! The weather going to be bizarre the rest of the week! It's going to be beautiful, in between when it's NOT! Good luck in advance everyone.
    After nearly a month, Little Big Red will come home today, with an entirely new AC. Yes, almost every component. :spending: What caused the problems when all the new stuff should have been working? The E-Fan. It's now ripped out, and a new clutch and fan blade in it's place. I have to put a new old shroud in this weekend. Definitely going to be a "phase" in the LBR story......
    jmdaniel, roundrocktom and ryanbitt like this.
  7. May 18, 2021 at 7:11 AM
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    :annoyed:
    riz_atx[QUOTED] and Oldie2007 like this.
  8. May 18, 2021 at 7:16 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    At least yours doesn't have the timing cover leak! I'm dreading that one :bananadead:
    riz_atx and Oldie2007[QUOTED] like this.
  9. May 18, 2021 at 7:29 AM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    Don't overlook shelves 3' deep at the front of the garage, a good 6" above the hood! The Hood of the car tucks in under the shelves but keeps the floor and parking area clear. Not enough space, time to toss things out!
    When was the electric fan installed?
    OEM Fans work great when they work. Honda electric fans are incredible for how much air they pull, but a rubber flapper needs to be in place. Highway speed, enough air passes through the radiator, and that rubber flap opens to let air pass. In stop ad go traffic, the fan kicks on, sucking the rubber flap closed, pulling all the air through the radiator & AC condenser. Something still seems odd (I get absent-minded, but if AC was working while driving above 40 mph but not in traffic, it would help explain what happened).
    My classic was a rotary-engined Mazda. The fan coupling bolts to the eccentric (crankshaft). We modified the motor to be able to hold 10,000 rpm. Well, the viscous coupling has a bearing in there. Bearings seized. So fan was direct coupled to the engine. Peripheral ported bat out of hell engine. Typically those fans never go over 3,000 rpm. One of the blades let loose at 10,000 RPM. It shook so badly the gear shift knob left black and blue welts on my thigh! We ended up taking the fan off since the drive home was 300 miles of straight highway. All would have been fine, but I failed to shut down the engine at the one railroad crossing, and it cooked. Still drove home, but the next morning all the aluminum rotor housings were toast and couldn't hold water. Cast iron, aluminum, cast iron, aluminum, cast iron like making a club sandwich!
    Oldie2007[QUOTED] and ryanbitt like this.
  10. May 18, 2021 at 7:38 AM
    Oldie2007
    Kurt
    Lockhart, TX
    According to Toyota, it does. According to the lack of drips anywhere, it's not serious enough to worry me.
    ryanbitt[QUOTED] likes this.
  11. May 18, 2021 at 7:47 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    I'm excited for this as well! The new garage ceilings are 1-2ft higher than the current ones so we can actually do this
    Oldie2007 and jmdaniel[QUOTED] like this.
  12. May 18, 2021 at 7:53 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    That's what I said about 6 years ago :rofl: it's still not too terrible but it makes a huge mess on the undercarriage and driveway :bananadead:
    Oldie2007[QUOTED] likes this.
  13. May 18, 2021 at 7:54 AM
    jmdaniel
    Jeff
    Leander, TX
    If you buy some, I recommend the Gladiator brand. My neighbor bought another brand, and the base was fully assembled, rather than the welded wire type that Gladiator sells. When we installed his, he had a problem with one of the bolts, so I was on a ladder, holding the base in place with my back, while he was laying on it. He's not a big dude, but I'm not young, either. With Gladiator, you hang the framework, then toss the welded wire base in place. Much easier.
  14. May 18, 2021 at 7:55 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    Just got a quote for the hell of it...$3600 to reseal timing cover and replace waterpump :bananadead: Maybe I should just trade it off :rofl:
    Oldie2007 likes this.
  15. May 18, 2021 at 7:57 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    Good to know! I had a saferacks 4'x8' before and it was decent...similar setup as you're describing
  16. May 18, 2021 at 8:04 AM
    jmdaniel
    Jeff
    Leander, TX
    Yeah, he was laying up there for about 5 minutes, and I have three herniated discs in my lower back. Not fun. I had rec'd the Gladiator product to him before he bought what he did, and it was out of stock. I did my install myself, there is no way he could have, as you have have to manhandle that section, while bolting it in.
    Oldie2007 and ryanbitt[QUOTED] like this.
  17. May 18, 2021 at 8:05 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    Yeah screw that! haha :rimshot:
  18. May 18, 2021 at 8:08 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    I've got a similar setup in my garage as well. I have a buddy who did the install for me. Be sure to not put stuff near the edge where it could fall off and smash the windshield on your Tesla.
  19. May 18, 2021 at 8:10 AM
    GeoTachnical
    Nick
    Austin, Texas
    They quoted me 1900$ for a 1 step paint correction and ceramic coat for my taco and the camper shell. Seems a bit high to me. Thoughts?
  20. May 18, 2021 at 8:12 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    EEEEPPPPPP!
    Oldie2007 and riz_atx[QUOTED] like this.
