Austin Area TW Chapter (all gens welcome, even T4Rs; heck, just make it a Toyota and we're good)
Discussion in 'Texas' started by CaptAmerica, Jan 18, 2016.
  1. Jun 14, 2016 at 9:57 AM
    #881
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    You could possibly look for some takeoffs from a 2016, they are actually a little taller than a 2nd gen spring and give about an inch of lift if that is something you want.
    ChadsPride likes this.
  2. Jun 14, 2016 at 10:00 AM
    #882
    Spansfelder
    Spansfelder Well-Known Member
    Austin, TX / Germany
    05 4WD
    Actually not looking for a lift, since I have the 6 inch fabtech lift. Just wondering if there is an upgrade to the regular SR5 coils.
    I was thinking about about replacing the 6" spacer with a 3" spacer and them run an OME setup, but I found a thread where people say that rides like s***.
    Also need to figure out on how to compensate the extra weight on the front (skids, bumper and soon winch). That was another reason I considered OME.
  3. Jun 14, 2016 at 10:06 AM
    #883
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
  4. Jun 14, 2016 at 10:10 AM
    #884
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The TRD coils are wound tighter at the top to make them progressive, which means as they compress, they will get tighter than regular coils. That makes for a stiffer ride with the bilsteins. Fox and others make coil over assemblies for 6" lifts that will improve ride quality over having the spacer
  5. Jun 14, 2016 at 10:10 AM
    #885
    Spansfelder
    05 4WD
    The spacer is not really an issue on that lift, since it basically accommodates to the drop bracket.
    But it seems there no upgraded springs without adding a lift.
    *edit*
    Just looked at the ICONs, the would work, but damn that's steep......
  6. Jun 14, 2016 at 10:18 AM
    #886
    qxrtz4321
    qxrtz4321 Well-Known Member
    Mitch
    Montana / Washington
    FYI I have a full take off Suspension parts from my 2016 TRD OR took it all off with ~4 or 500 miles. UCAs, rear shocks, front coil overs. I'm in Austin and would do $150 for them
  7. Jun 14, 2016 at 11:44 AM
    #887
    Spansfelder
    05 4WD
    Mine is a second gen, but it seems the coils would be an upgrade. Care to separate??
  8. Jun 14, 2016 at 11:52 AM
    #888
    qxrtz4321
    Mitch
    More work than it's worth for me I don't have a spring compressor.. Just out of curiosity what shocks are you using that you wouldn't want the new Bilsteins that the springs are mounted to?
  9. Jun 14, 2016 at 11:53 AM
    #889
    Spansfelder
    05 4WD
    Bought a set of Bilstein 5100's. Would the full strut bolt up?
  10. Jun 14, 2016 at 11:55 AM
    #890
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Can separate those in a matter of probably 15 minutes.
  11. Jun 14, 2016 at 11:56 AM
    #891
    qxrtz4321
    Mitch
  12. Jun 14, 2016 at 12:00 PM
    #892
    Spansfelder
    05 4WD
    I bought the 5100's on CL, I doubt the guy takes em back :D
    Do you know if the spring rate is different between the 2016 and 2nd gens? If the spring rate is a little higher, it could accommodate for the added weight on the front.
  13. Jun 14, 2016 at 12:07 PM
    #893
    qxrtz4321
    Mitch
    I don't know about the spring rate, but I do know the 3rd gen front end weighs more ;) So I'm sure that would work out for you.
  14. Jun 14, 2016 at 1:13 PM
    #894
    Spansfelder
    05 4WD
    Sold, let's see how that works out. I'll report back.
    My 5100's will be up for grabs if somebody needs them.
  15. Jun 14, 2016 at 1:19 PM
    #895
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Psh, more like a minute if you have balls of steel
  16. Jun 14, 2016 at 1:31 PM
    #896
    Spansfelder
    05 4WD
    I shot a coil through a fire proof metal door after a spring compressor failed.....
    You should take your time, that kind of stuff is dangerous......
  17. Jun 14, 2016 at 2:07 PM
    #897
    CedarPark
    Dylan
    Cedar Park, TX
    Damn, for real?
    Yeah, I wouldn't condone shooting a coil spring, just tryin to get some cheap laughs :rofl:
  18. Jun 14, 2016 at 2:10 PM
    #898
    Spansfelder
    05 4WD
    Yup, that was scary as hell! I always make sure there is nobody in front or behind the spring.....
    Did another BMW a few month ago and when the top nut came off it made a weird sound. Almost lost it and saw the coil flying through the garage again (the noise came from the old shock, zero compression).
  19. Jun 14, 2016 at 2:35 PM
    #899
    CedarPark
    Dylan
    Cedar Park, TX
    That's scary as shit, lol. Doing @Toyboata 's lift was about as sketchy as could be. Having to alternate sides with the compressors to get it to compress. Had it pointing at a empty field just incase :rofl:
    Toyboata likes this.
  20. Jun 14, 2016 at 2:49 PM
    #900
    Spansfelder
    05 4WD
    I guess I worded that wrong, when it made that weird sound I thought the compressor broke again. Nothing happened but it scared the shit out of me.....
