Austinrauh's tacoma
Discussion in '2nd Gen. Builds (2005-2015)' started by austinrauh, Dec 28, 2016.
  1. Mar 20, 2017 at 9:52 AM
    austinrauh
    austinrauh [OP] Well-Known Member
    Nevada
    05 AC OR
    It's been there for a while, but I had always thought it was a worn out brake, so I replaced rotors and pads and it was still there
  2. Mar 20, 2017 at 10:28 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I hear it from one side only when I'm backing up slow, and only on a damp morning. Not too concerned
  3. Mar 20, 2017 at 10:30 AM
    austinrauh
    Nevada
    05 AC OR
    it could be a brake, sound clips make it easier, but i kinda worked outward in.. so first i did brakes, not gone, changed cv, not gone, now I'm at the hub and I'm 99.999% sure its the hub
  4. Mar 20, 2017 at 12:41 PM
    austinrauh
    Nevada
    05 AC OR
    I would also jack up that side and see if you could feel any play in the wheel, or take off the wheel and get a good grab in the rotor, if there's play it will be obvious,
    It could be: upper/ lower ball joints on uca or lca
    Hub bearing
    Cv
    Tie rods
  5. Mar 27, 2017 at 12:07 PM
    austinrauh
    Nevada
    05 AC OR
    New front brake pads
    New passenger side hub assembly (jersey built)
    Joints greased both sides
    (Note: rubber on passenger cv doesn't look perfect, upper control arm boots not looking so hot either)
    New All Pro standard leaf pack (painted and cleaned up, all joints greased well)
    Probably need u bolt flip and extended brake lines
    Rear went 43 to 44" inches wheel to hub, both sides
    Carpeted the rear droor system, thanks dad!
    (You can see why I got a warranty replacement, just out of the top of the pad)
    ChadsPride and SonnyBones like this.
  6. May 21, 2017 at 11:04 PM
    austinrauh
    Nevada
    05 AC OR
    Got a lot done today at 188,000 miles (5/21/17)
    -painted axle/ drum brakes
    -6 new denso spark plugs
    -cabin air filter
    -relentless u bolt flip kit
    -transmission fluid (Toyota atf ws) 3.5qt.s~
    -rear diff fluid 2.5qt.s~
    -12 rear wheel studs
    This is a Exactly how I pulled it out?!
  7. May 27, 2017 at 6:26 PM
    austinrauh
    Nevada
    05 AC OR
    New air filter and made a box out of sheet metal for it
    ChadsPride likes this.
  8. Feb 4, 2018 at 10:38 PM
    austinrauh
    Nevada
    05 AC OR
    Current rack setup, I have a buddy who has access to a plasma cutter that he can program on a computer to make new sides for the camper rack, those are just temporary, also want to make the box fit lower somehow..
    I made the the rear rack.
    Have been thinking of shaving some material off the spacers for the prinsu rack to make it sit lower closer to the roof of the truck, has anyone done this?
    Also plan on making the rear LED’s a little more hidden or not stuck up as much.
    But it works great, I can turn every light on individually.
    37A33177-BCF9-4DAF-A3D4-287C32E12ACA.jpg 6EFB1C21-6269-44C9-B187-2028AFD7EBD2.jpg
  9. Feb 7, 2018 at 11:48 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Good lookin rig!!! ​
  10. Feb 7, 2018 at 11:51 AM
    austinrauh
    Nevada
    05 AC OR
    Thanks! Now the thread is official with you here! Haha:hattip:
    ChadsPride[QUOTED] likes this.
  11. Feb 7, 2018 at 11:54 AM
    ChadsPride
    :woot:
    Sorry for the late arrival!!!
  12. Feb 10, 2018 at 2:09 PM
    austinrauh
    Nevada
    05 AC OR
    -new derp on roof
    -shaved the spacers on prinsu rack
    Before
    After
