Austin's Supercharged Mid Travel Build
Discussion in '1st Gen. Builds (1995-2004)' started by austinmtb, Oct 13, 2017.
  1. Jan 14, 2019 at 6:36 PM
    #281
    austinmtb
    austinmtb [OP] Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Luckily it has a lifetime warranty so I'll swap the part and give that a try.
    I think I'll also try swapping ignition coil A and B and see if the code follows the ignition coil over to B. Seems like a good way to isolate if the issue is really in the ignition coil or not.
    I fixed it by replacing the ignition coil pack A.
    The valve is making a liquidy sound as well as a clicking sound. It's not super loud. I can hear it in the drivers seat very faintly.
  2. Jan 14, 2019 at 9:04 PM
    #282
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    That valve is one of the doors in the HVAC and is probably operated by an actuator motor of some kind on a 2004. My 99 doesn't have that, it's all manual but my 2004 Ram uses actuator motors for all the doors in the HVAC system. They do go bad sometimes so you might have to dig into the dash/HVAC system to remedy that problem. That white arm operates the door, if you can disconnect the motor from it, you can verify if the door moves freely or not and rule that out. If it does, then the actuator motor is the issue.
  3. Jan 14, 2019 at 9:10 PM
    #283
    austinmtb
    Austin
    Southern Oregon
    Thanks for the info. I have noticed my HVAC system hasn't been working all that great lately. I wonder if that's the culprit...
  4. Jan 14, 2019 at 9:12 PM
    #284
    austinmtb
    Austin
    Southern Oregon
    Update:
    Swapped the new ignition coil A to B, and put the B ignition coil on A and the truck started running fine again.
    Any idea why this would be? It's my understanding that all ignition coils are the same.
  5. Jan 14, 2019 at 9:14 PM
    #285
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Hopefully it's just the actuator and not the door itself. If it's the door that is having issues, then you have to tear the whole dash out to get the the HVAC system. It's a pain in the ass, I had to do it on my Ram to fix broken doors.
  6. Jan 14, 2019 at 9:20 PM
    #286
    austinmtb
    Austin
    Southern Oregon
    Ah shit yeah hopefully it's not that! So by disconnecting the door from the servo I can determine weather it's the servo or the door that's bad correct? If the door is having issues will it just be stuck and not want to move?
  7. Jan 14, 2019 at 9:46 PM
    #287
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Most likely, that would be the case. You should be able to hear the door move when you move it by hand. And with the servo disconnected, you could test that too by playing with the various controls for the HVAC and see if it does anything.
  8. Jan 15, 2019 at 9:34 AM
    #288
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Pull the coil packs and check the resistance in the with a meter. I can't 100% remember what they are supposed to be but I have a photo somewhere ill dig up.
    Sounds like the servo or the switch for the vents is bad. Electrical problem for the HVAC which can either be simple or near impossible to find
  9. Jan 15, 2019 at 1:13 PM
    #289
    austinmtb
    Austin
    Southern Oregon
    Already checked out all the coil packs with a meter. The one the truck was throwing a code for was bad, but even after replacing I'm still getting the same symptoms and code. Last night I moved the new coil pack from A to B, and put the one that was on B onto A thinking it would throw a error for B if the coil pack was the issue. The truck drove fine today on my way to class, but on the way home died and threw the p0351 code for coil A once again. So now it seems like the issue is something else, which is really strange because the original coil pack that I replaced was in fact bad.
  10. Jan 15, 2019 at 1:18 PM
    #290
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Maybe the truck ICM isnt going from start mode to run mode thus dumping too much voltage into coil a?
  11. Jan 15, 2019 at 1:22 PM
    #291
    Blackdawg
    Monte
    Wyoming/St. Louis
    Have you check the ECU ground in the engine bay?
  12. Jan 15, 2019 at 1:22 PM
    #292
    Dan8906
    Daniel
    Concord, California
    Also check the gaps on you spark plugs? if they are over gapped that could cause issues maybe.
  13. Jan 15, 2019 at 1:28 PM
    #293
    austinmtb
    Austin
    Southern Oregon
    Possibly, is there a way to test to see if this is the case?
  14. Jan 15, 2019 at 1:28 PM
    #294
    austinmtb
    Austin
    Southern Oregon
    I have not. Do you know where the ground is located?
  15. Jan 15, 2019 at 1:34 PM
    #295
    Blackdawg
    Monte
    Wyoming/St. Louis
    It was on the intake that you replaced with the blower. Driver side. Was bolted right to the bend of the intake and should now be bolted to the blower on the side.
    austinmtb[QUOTED][OP] likes this.
  16. Jan 15, 2019 at 3:47 PM
    #296
    Dan8906
    Daniel
    Concord, California
  17. Jan 15, 2019 at 6:37 PM
    #297
    austinmtb
    Austin
    Southern Oregon
    Checked the ground and it was all good. Went ahead and cleaned it up anyways.
    I just swapped the spark plugs that A fires over to B, and the plugs that B fires over to A. The truck started running fine again. I guess I just have to drive it and wait to see if it now throws a code for B. If so then I can rule it out to being the spark plugs, and if it throws another code for A then it's probably the igniter.
  18. Jan 15, 2019 at 7:14 PM
    #298
    Dan8906
    Daniel
    Concord, California
    Yeah
    I’m really wondering if the ICM is failing. That’s why it’s dying after driving it a while. Stuck on start up mod and frying out the coils. I think they run like 200-300? Maybe buy a new one and see if it changes anything. If not return it
  19. Jan 15, 2019 at 8:01 PM
    #299
    austinmtb
    Austin
    Southern Oregon
    Seems like that's what's most likely the issue. I would think that a spark plug, coil pack, or wiring issue would be consistent. The ICM seems like the only thing that could cause intermittent issues.
    Dan8906[QUOTED] likes this.
  20. Jan 17, 2019 at 8:01 PM
    #300
    austinmtb
    Austin
    Southern Oregon
    Lately I've been thinking about taking the pump and water lines out of my engine bay, and building a shower box instead. I could mount the pump in a box with clip on battery connectors and keep the water lines in there as well. I'd just put quick disconnects on the heat exchanger to quickly connect and disconnect the water lines. It would be easy to just grab when going camping / road trips.
    I use my ARB air compressor (which is currently mounted in a box) a lot more than I use the shower, so I think it would make more sense to mount the ARB compressor in the engine bay, and the shower in the box the compressor is in.
    This would also help free up some room for when I re-install my second battery in the back passenger side of the engine bay.
