Austin's Supercharged Mid Travel Build
Discussion in '1st Gen. Builds (1995-2004)' started by austinmtb, Oct 13, 2017.
  1. Apr 13, 2020 at 6:25 PM
    #661
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    You could put them in a battery box. They’ll be more protected than under the hood or under the bed. Downside is they’ll take up bed space. Another upside to both is less heat.
    An Anderson plug would work. How about a big blue sea’s battery switch?
    Sweet truck by they way!
  2. Apr 13, 2020 at 6:31 PM
    #662
    austinmtb
    austinmtb [OP] Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I'm not a fan of batteries in the bed but if I do relocate them under the bed I'll wrap them in some 1/4'' plate to make sure that nothing will happen if they take a hit.
    I really like the idea of the blue sea battery switch.
    otis24[QUOTED] likes this.
  3. Apr 13, 2020 at 8:33 PM
    #663
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If you still have OEM fenders, I bet @eon_blue would love to buy the set off of you to replace his thin aftermarket one.
  4. Apr 13, 2020 at 8:39 PM
    #664
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Fiberwerx. I'd get advanced glass though next time. Although advanced gladd is only 3.5" flare so barely wider than stock. Mine were 4.5 I think.
    Box rocket had 3.5 flare glasswork(advanced glass now runs it) with just 33s and it looked good.
    I'd not run rear glass honestly. Smallest you can get is 6" flare per side. Not worth it.
  5. Apr 13, 2020 at 8:43 PM
    #665
    austinmtb
    Austin
    Southern Oregon
    Looks like advanced makes a 4'' https://www.advfiberglass.com/products/1995-2004-toyota-tacoma-bedsides
  6. Apr 13, 2020 at 8:46 PM
    #666
    eon_blue
    Azusa, CA
    Sure would, finding a radiant red OEM used one in decent shape hasnt been easy.
  7. Apr 13, 2020 at 8:47 PM
    #667
    austinmtb
    Austin
    Southern Oregon
    Well it won't happen anytime soon, but if I do decide to go the fiberglass route I'll let you know.
    eon_blue[QUOTED] likes this.
  8. Apr 13, 2020 at 8:55 PM
    #668
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Apr 13, 2020 at 9:00 PM
    #669
    austinmtb
    Austin
    Southern Oregon
    Good point, didn't really think of that.
  10. Apr 14, 2020 at 7:36 AM
    #670
    cynicalrider
    cynicalrider #NFG
    Jersey
    I've always wanted glass to get rid of the fender holes. Would look cleaner in general IMO. But I think I would want to do it to a newish/better condition bed too, mine has seen better days between all the holes I have drilled and shit I have cut/dented into it. I say def go for the glass up front.
    austinmtb[OP] likes this.
  11. Apr 14, 2020 at 8:59 AM
    #671
    austinmtb
    Austin
    Southern Oregon
    @Blackdawg when you had 35's and mid travel did you rub anywhere at the top of the wheel well? Like airbox or battery mount area?
  12. Apr 14, 2020 at 9:12 AM
    #672
    JasonLee
    15 TRD OffRoad
    @m3bassman is working through these issues right now.
    https://www.tacomaworld.com/threads/fitting-35s-on-3-suspension-lift.307596/
    austinmtb[QUOTED][OP] likes this.
  13. Apr 14, 2020 at 9:33 AM
    #673
    austinmtb
    Austin
    Southern Oregon
    Is that at full bump?
  14. Apr 14, 2020 at 9:43 AM
    #674
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah you gotta do some hammering along the top for sure on the driver side.
    Less so on the passenger side but that's because the washer bottle is in the way and just come's out completely for 35s.
  15. Apr 14, 2020 at 10:38 AM
    #675
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    rear glass would look weird with your bumper, but this is fiberwerxs 4.5in rear on 35s and a t100 axle on flapjacks truck
  16. Apr 14, 2020 at 10:49 AM
    #676
    austinmtb
    Austin
    Southern Oregon
    Maybe I'll just have to build a new bumper with a single tube wrapping around under the bedside.
    I won't do front glass without rear glass. Just don't like the look of front glass without flares combined with stock bedsides with flares, or having glass up front and the flare holes being exposed in the rear.
  17. Apr 14, 2020 at 10:50 AM
    #677
    JasonLee
    15 TRD OffRoad
    Fernando and austinmtb[OP] like this.
  18. Apr 14, 2020 at 10:50 AM
    #678
    austinmtb
    Austin
    Southern Oregon
    Looks great!
  19. Apr 14, 2020 at 10:51 AM
    #679
    austinmtb
    Austin
    Southern Oregon
    Anyone know how much wider a t100 or tundra axle is over ours?
  20. Apr 14, 2020 at 10:54 AM
    #680
    Phessor
    Phessor Well-Known Member
