Auto 2nd Gear Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by andymcd, Nov 23, 2020.
  1. Nov 23, 2020 at 7:17 AM
    andymcd
    andymcd [OP] Member
    Went offroading with a friend in his 100 series landcruiser this weekend and his truck has a button for starting in 2nd gear, which is quite nice when in low range and you dont need to crawling capability of 1st gear.
    I know our trucks dont have the same button but is there any way to override the trans to start in 2nd when using low range? 1st gear in low is so jerky when not crawling and the shift point is too high for my liking.
    MOC221_ likes this.
  2. Nov 23, 2020 at 8:23 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I don't dare say it.
    The backlash would be epic.
    Ck1010, Junkhead, Skydvrr and 2 others like this.
  3. Nov 23, 2020 at 8:25 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    You can start off in 2nd gear with a standard transmission.
  4. Nov 23, 2020 at 8:48 AM
    MOC221_
    Frank
    You must be vegan.
    ..or wear a man-bun.
    How dare you.
    Junkhead and batacoma[QUOTED] like this.
  5. Nov 23, 2020 at 9:05 AM
    gearcruncher
    Canadain bumper technician
  6. Nov 23, 2020 at 9:13 AM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    Don't you just use "select" mode and put it in 2nd? I do it all the time when 4-wheeling, is it really in 1st no matter what the display shows? I just looked at the manual and it doesn't really say. Just says it will go to 5th or 4th depending on speed or 3rd if you go directly from park?
    TheThorn likes this.
  7. Nov 23, 2020 at 9:17 AM
    mchertel
    Mark
    Colorado Springs CO
  8. Nov 23, 2020 at 9:21 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I thought the same!
    :rofl::rofl:
    Glad someone did...
    Ck1010 likes this.
  9. Nov 23, 2020 at 9:43 AM
    gearcruncher
    Yes , 2 wheel drive but I believe members at Tacoma World are working on a magic box that combines the 2 low mod with the grey wire mod . They are talking about a magic box that will let you start off in second gear using 4 low , allow your locker to stay locked , as well as starting off in second gear in 2 wheel drive
    https://www.tacomaworld.com/threads/grey-wire-mod-2016.410443/
  10. Nov 23, 2020 at 9:46 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Doesn't this generation have a Hill Ascent mode of some sort? That's basically what I use my Land Cruiser 2nd gear start for and also slippery surfaces.
  11. Nov 23, 2020 at 9:48 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I believe S mode only limits the vehicle from going into any gears above that. It doesn't manually shift the truck into 2nd if you put it on S2. I could be wrong, but that's explanation I've been given on here before.
    Chew likes this.
  12. Nov 23, 2020 at 9:51 AM
    batacoma
    batacoma Truck Wars
    No way!
    I do Crossfit though.
    RedWings44 likes this.
  13. Nov 23, 2020 at 9:51 AM
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Tested that on a test drive last week: Came to a stop in 2nd gear at a light on flat ground and wanted to see what it felt like to start in second on the automatic. Felt exactly the same as starting in first, including shifting into second.
    The S mode is no different than downshifting in any other automatic. It won't let you exceed that gear, but it won't actually let you select it like you can in a manual.
    mchertel[QUOTED] and RedWings44 like this.
  14. Nov 23, 2020 at 9:52 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This may be a stupid question, but if you're not crawling, why would you be in 4lo in the first place?
    Chew and Junkhead like this.
  15. Nov 23, 2020 at 9:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You got it right. It is just like PRND321 or PRND32L of old. Put it in 3, and it will drive like a three speed. Put it in 2, and it will drive like a two speed.
    Junkhead and RedWings44[QUOTED] like this.
  16. Nov 23, 2020 at 10:07 AM
    Syncros
    Syncros Well-Known Member
    My 2008 Subaru Impreza has this feature. At a stop, using the manual mode upshift once and "2" will display in the cluster. Another hidden feature is in "D", tap the accelerator twice and it will downshift.
    My 6MT Frontier Pro-4x is much more enjoyable here in the mountains. The 4.0L and gearing have a lot to do with that.
  17. Nov 23, 2020 at 10:25 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Exactly my thoughts.
  18. Nov 23, 2020 at 10:30 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    meh, I use 4lo on the beach even if I’m not crawling. Keeps the rpms down and saves my clutch. I can also start in 2nd gear(or 3rd) if I need to ;).
    OP, probably not much you can do as someone already mentioned S2 will make it so your truck doesn’t go into 3rd but won’t start it in 2nd.
  19. Nov 23, 2020 at 10:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's different for us in a manual, I'm in 4lo all the time too. But he's an auto and doesn't have to worry about feathering a clutch over every little thing.
    Junkhead likes this.
  20. Nov 23, 2020 at 10:33 AM
    stevesnj
    Some type of mod, break out box, would have to trick the trans to think that 1st gear solenoid has cycled and to trigger the 2nd gear solenoid off throttle. Probably what my Land Cruiser button does as I can use it in AWD, 4Hi and 4lo while the selector is in 'D'.
