Auto Adjust Drums to Tight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mystert, Oct 3, 2017.
  1. Oct 3, 2017 at 5:54 PM
    mystert
    mystert [OP] Well-Known Member
    Eric
    Ventura CA
    2005 Tacoma TRD Sport 4x4 6spd
    I was looking at old threads on here about adjusting the rear drum brakes using the hand brake handle in reverse. I went ahead and adjusted the brakes using that method. In the las I've always spun the star wheel with a screw driver and have over tightened brakes before. Is it possible to overtighten the rear brakes using the handbrake in reverse method?
  2. Oct 3, 2017 at 8:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, it is not possible to over tighten the rear brakes using the handbrake in reverse method.
    Hand tighten the brakes by spinning the wheel and tighten the star wheel until the drum locks then back the star wheel off 15 clicks. This is per the Toyota service manual.
    JoefromPTC likes this.
