Auto Body
Discussion in 'Technical Chat' started by fishinosprey46, Oct 31, 2012.
  1. Oct 31, 2012 at 2:13 PM
    fishinosprey46
    fishinosprey46 [OP] New Member
    Kenny
    Portland Oregon
    97 Tacoma 4WD X-cab
    air bags for camper hauling
    Greetings, Can someone tell me the PROPER way to remove the little black plastic pins with the large flat heads that hold rubber shields or plastic shroud material on to the body framework? Is it possible to remove them without destroying them? Where is the best place to get these? What are they called? Thanks everyone!!!:rolleyes::rolleyes::rolleyes: Kenny C.
  2. Oct 31, 2012 at 2:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think you use a flat head screw driver and lift up the center button (it pulls out) and that releases the whole shebang to pull straight out.
