Auto-Dim Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Airborne22, Nov 28, 2022.
  1. Nov 28, 2022 at 11:43 AM
    Airborne22
    Airborne22 [OP] It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    Hey all, I have a 2018 dbl cab and within the past few weeks I have noticed that the rear view mirror is not dimming. The power light is still on and if I hold my hand over the sensor on the back it will slowly dim. Anyone else have this issue?
  2. Nov 28, 2022 at 11:55 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Do you have tint on the back window? If so, how dark is it? Do you have dirt/filth/film on that window also? Make sure the glass is thoroughly cleaned. It may be that the unit itself is going bad and might need to be replaced.
    You can never find "just" the sensor. Usually you gotta buy the entire unit.
    Chew likes this.
  3. Nov 28, 2022 at 12:06 PM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    Thanks for the response. Noting with my truck has changed recently. The window is a tiny bit dirty, but I wouldn't think it would be enough to affect the mirror. Probably going bad.
  4. Nov 28, 2022 at 1:14 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    The rearview mirror should darken when exposed to bright headlights approaching from the rear, with the goal being to reduce the reflection onto your face. It should not darken when shielded by your hand, assuming the sensor you refer to actually controls the darkening of the mirror.
    Chew and ToyoTaco25 like this.
  5. Nov 28, 2022 at 1:17 PM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    You are correct...sorta...The dimming feature is based on the amount of light in both directions. The darker it is in front of you the darker your rear view will be. The sensor I am referring to is located behind (windshield side) of the mirror.
    ktbell444 likes this.
  6. Nov 28, 2022 at 1:27 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    It sounds like the mirror is fine. The foward facing sensor detects daylight, while the rear sensor detects headlights behind you. If the forward sensor does not detect much light (telling the rearview mirror that it's night) and the rear sensor detects enough light (signifying that a car behind you is pissed off) then it will dim. You covering the sensor in the daytime (I assume) and it dimming sounds like both sensors are working as they should. Also, just to be clear, it doesn't always dim at night, it needs to detect light from behind you.
  7. Nov 28, 2022 at 1:28 PM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    No, I am covering it at night. Its weird.
  8. Nov 28, 2022 at 1:37 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
