AUTO-DIMMING MIRROR with COMPASS and outside TEMPERATURE installation
Discussion in '1st Gen. Tacomas (1995-2004)' started by nissanh, May 27, 2014.
  1. May 27, 2014 at 4:49 PM
    nissanh
    nissanh [OP] Member
    This is my first thread on tacoma world.
    I installed an autodimming mirror into a 3rd generation 4runner and recently installed it to a 1st generation tacoma.
    Installation was simple and I will include all the steps I took for the installation.
    I also have several auto-dimming mirrors and the sensor (used in this installation) for sale.
    Items required: Mirror, Sensor, mirror mount button ($4 at any auto parts store) wires (1 roll from Walmart is sufficient), electrical tape, cable ties.
    1) Disconnect the ground terminal
    2) remove the driver side grab handle on the pillar
    3) Using a flat screwdriver lift the pillar cover (only on the two locations shown in the picture).
    4) Lift up the pillar cover (note the locking tab on the bottom of the cover)
    5) lift the reading lamp cover by inserting a flat screw driver from the back.
    6) unscrew the 4-philips bolts and lower the unit.
    7) remove the wire plug
    8) Run 3 wires from the opening of the roof to the driver side pillar
    9) one wire should run to the fuse box by the driver's knee.
    10) other two wires must run through the rubber grommet to the front lower turn signal area (to mount the sensor).
    11) Attach one (about 8 inches long) to the negative wire in the mirror
    12) remove the mirror mounted into the reading lamp (watch for the 3-tiny parts that comes lose)
    13) locate the center and mark the windshield from outside with a sticker or a marker.
    14) glue the mirror mount button (read instructions on the mirror mount button packet). Let it dry 24 hours before mounting the mirror
    15) Run the mirror wire plug through the opening in the reading lamp base.
    16) connect the 12V power wire to a fuse (that gives 12V only when the ignition is on- otherwise the mirror will be on even without the key in the ignition)
    17) mount the reading lamp base to the roof and leave enough wire length to attach to the back of the mirror.
    18) put everything back on.
    19) attach the temperature sensor to the wires pulled to the front of the truck.
    20) Use a cable tie to mount the sensor (not closer to the radiator/ac condenser)
    21) mount the mirror
    22) reconnect the ground terminal
    23) calibrate the mirror based on the zone you live in according to the following link
    That is all.
    To calibrate the unit, please visit page 11: http://allscion.com/images/rostra/Installation instructions for all mirrors.pdf
    Here is 96-02 4Runner (shares same setup as a tacoma) installation DSCN1459.jpg
  2. May 27, 2014 at 5:46 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    x2
  3. May 27, 2014 at 8:00 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Cool mod. Great write-up! Thx for sharing!
  4. May 28, 2014 at 1:45 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Great write up and pictures. Keep these mirrors in stock. Wouldn't mind trying to add this to my 95 taco.
  5. May 28, 2014 at 5:52 AM
    nissanh
    nissanh [OP] Member
    Thanks for all the nice comments!
  6. May 30, 2014 at 11:49 AM
    voodoodb
    voodoodb Member
    Mississippi
    04 Prerunner Limited V6 TRD
    Very Nice!!
