Auto headlights not working..any suggestions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBoutNothing, Feb 22, 2024.
  1. Feb 22, 2024 at 9:51 PM
    TacoBoutNothing
    TacoBoutNothing [OP] Well-Known Member
    2019 White TRD Pro
    Hi All. I’m stumped and looking for help. I have a 19 Pro that has been perfect. I recently installed a Redarc Liberty trailer brake controller and noticed my head lights were out. I uninstalled the controller and still no lights. Checked fuses and relays. All good. Checked bulbs. Both blown (low beams). I replaced both low beams with H11 bulbs. Low beams will work when manually turned on, but not in auto. I know the sensor is working because dash and radio dim correctly after sunset and in tunnels/under bridges. I realize this may seem like a dumb problem, but my new to driving teenager drives the truck and I’m very worried about her driving without headlights. I hooked up an obd reader and zero codes. I’m incredibly stumped on this one. Any help, ideas, or thoughts?
  2. Feb 22, 2024 at 11:42 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    You added a controller, probably leaving battery connected. It blew the headlight bulbs so *something* worked its way through your electrical system. Now you have mixed response in the electrical system.
    I advise disconnecting the battery for 30 minutes. Let the electrical system have a nice long nap and lose all incorrect memory settings. Cannot hurt anything. Your auto-headlights may well come back, then you can install the H9s again.
    Blockhead likes this.
  3. Feb 23, 2024 at 7:20 AM
    TacoBoutNothing
    2019 White TRD Pro
    You’re absolutely correct. I foolishly did not disconnect the battery prior to installing the Redarc. I’ll go try a battery reset. Thank you for the suggestion
  4. Feb 23, 2024 at 7:28 AM
    RichochetRabbit
    Learn from your error ... assuming this works. Life is full of this annoying "learning". :cheers:
