Auto high beam upgrade / mod?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Dec 11, 2018.
  1. Dec 11, 2018 at 7:08 AM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Is this possible? I have a 2016...
  2. Dec 11, 2018 at 7:10 AM
    trackdaybro
    trackdaybro Well-Known Member
    Not worth the trouble retrofitting it since it’s tied into TSS and utilizes the cameras up front.
    FWIW I never use it. Maaaybe useful for long stretches of interstate at night? But in the city, streetlights and your own high beams reflecting off road signs trigger the AHB to turn the high beams off.
    broteinshaker and Dkurtz42 like this.
  3. Dec 11, 2018 at 7:12 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    His 2016 doesn't have TSS, but still not worth doing. Tons of threads about "I fucked with my lights, and now my truck doesn't work"
    G.
  4. Dec 11, 2018 at 7:36 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    It is not tied to TSS. His is a 2016, which is prior to TSS anyway. It does use a light sensor that would be located on the RH dash speaker (there is a blank there for those without). However, my understanding is that there is a good bit more to it than just a sensor and the light switch. Much of it is not present in trim without the Premium package. As nice as it sounds, not worth the effort/risk/reward.
    Garyji and Rujack[OP] like this.
  5. Dec 11, 2018 at 7:38 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    Not too many threads about this. The technology is too sensitive. The lights stay off 95% of the time. I turned it off and no longer use it. Not worth the headache in my opinion.
    daddy_o and Rujack[OP] like this.
  6. Dec 11, 2018 at 7:40 AM
    UAL777jet
    UAL777jet Well-Known Member
    Bill
    Norwalk, IA
    2019 Tacoma TRD Pro Voodoo Blue
    TRD Performance Air Intake
    Toyota still doesn’t have the bugs worked out on this feature. My Mercedes is 100% on dimming when it should, I don’t even have to look anymore. But the Tacoma is about 75%, just enough to annoy me when getting flashed by other drivers.
    Gator352 and Rujack[OP] like this.
  7. Dec 11, 2018 at 7:42 AM
    Rujack
    That’s kinda what I’d figured. I do tons of long distance driving though so that’s why I asked.
  8. Dec 11, 2018 at 7:43 AM
    trackdaybro
    I meant since his doesn’t have TSS, it’d be more intensive to retrofit in.
    Ah, I thought it was all tied in together since it’s a safety feature that started in 2018 as well. Good catch.
  9. Dec 11, 2018 at 9:21 AM
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    The problem is since all cars don't have it, the truck will turn off the highs and you still get high beamed. You can't even flick em back to high to remind the other driver, since the switch is under the left side dash.
  10. Dec 11, 2018 at 10:01 AM
    phadcock
    phadcock Member
    You can still flash people but you have to pull the headlight stalk back towards you through the low beam position and to the intermittent position. Then you have to remember to put it back into auto high beam mode.
    My issue with the system is that it will recognize tail lights and dim the highs for cars in that are in front of you...but when passing a longer transport it puts the highs back on about halfway along blinding the poor bugger when you're right beside him.
    It also won't dim the highs prior to seeing the other car such as when cresting a hill or on narrow twisties. Better to take over and do it yourself. I always found that when I start forgetting to dim the lights it meant I was getting tired and it was time for a break.
  11. Dec 11, 2018 at 10:31 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    I wish mine would auto come on when I’m passing idiots who put HIDs in their reflector housing. They are complete assholes. I usually keep my highs on when I see them.
  12. Dec 11, 2018 at 11:07 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Whoops! I mis-read this thread as the auto headlights that are part of the Premium package. This is in reference to the auto high beams. That is a totally different animal and I have not looked into that as it was on both my vehicles (2018 SR5 and OR). Others may be right that it involves the TSS as I'm not sure where light sourcing would be otherwise, since it references field of view.
