Auto Limited Slip Diff (LSD) on a 2007 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgord, Jul 28, 2017.
  1. Jul 28, 2017 at 6:23 AM
    mgord
    mgord [OP] Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    Don't know if this has been addressed before. I've looked and there are a lot of threads about mechanical limited slips.
    My question is is there a way to re-program my 2007 TRD Off-Road to get the Auto LSD? I'm not excited about changing diffs since I have the rear locker.
  2. Jul 28, 2017 at 6:52 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    The long and short of it is NO, you would need a need ABS unit (Skid control ECU), master cylinder, harness, switch(s), and possibly a cluster. No reprogram will do it.
  3. Jul 28, 2017 at 6:59 AM
    mgord
    Harrisburg, PA
    07 TRD
    Thanks for the quick reply.
    Any recommendations on a mechanical limited slip that will work with the rear locker?
  4. Jul 28, 2017 at 7:06 AM
    Jeffs68
    Stock
    A mechanical type LSD is basically just a "Posi" rear-end and uses clutches to keep both wheels hooked up, but allows the vehicle to turn without "wheel hop". You would have to completely change out the rear end. I know of none, but I do know it would be expensive.
  5. Jul 28, 2017 at 12:20 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    So you already have a mechanical LSD since it's an 07 right? Do you need to rebuild it since the clutches have worn out?
    PapaBear likes this.
  6. Jul 28, 2017 at 12:22 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    No you can't have locker and lsd. There might be a fancy super expensive unit out there that does it
  7. Jul 28, 2017 at 12:31 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Detroit Truetrac is a good option if you want to step away from clutch design. Personally I don't like it, for it to engage, the wheel that is spinning still needs a tiny bit of traction to get it going, you can always tap the brakes and it should catch and pull you up, but I'm a fan of clutch based. As long as you take care of it, it should last a while.
  8. Jul 28, 2017 at 1:30 PM
    mgord
    Harrisburg, PA
    07 TRD
    Thanks for the info. No limited slip in mine since the locker. Don't want to spend an arm and a leg so I guess I'll have to live with what I have.
