Auto locking hubs won't disengage
Discussion in 'Technical Chat' started by DirtyRider, Feb 3, 2013.
  1. Feb 3, 2013 at 3:28 PM
    DirtyRider
    DirtyRider [OP] New Member
    Western NC
    06 Tacoma 4x4 TRD Sport
    Had a snow here last night, put the truck in 4WD to get up the mountain I live on. Upon leaving this morning I shifted back into 2WD. I noticed as i took sharper turns the truck was jumping. I thought maybe it was still in 4WD but after messing with it most of the day it's obvious it is not. Only thing I can figure is the hubs are locked and won't disengage. Anyone else ever have this problem or have any advice on how to correct?
  2. Feb 5, 2013 at 7:04 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Have you tried going in reverse for a few hundred feet? That might do the trick.
  3. May 23, 2013 at 6:22 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    And take it out of 4wd when u reach the top of the mountain.
    Dont let it sit overnight in the cold with high humidity.
    It makes it harder to take out of 4wd, especially the next morning before it warms up.
  4. May 23, 2013 at 8:11 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    It is probably an ADD (on a 2001) and not AUTO LOCKING HUBS (but both do the same thing in providing free wheeling front end when in 2WD).
    In either case, on or off, doesn't affect steering. The transfer case still in 4WD will make steering difficult on solid surfaces or a locking rear differential in a locked position will. What do your dash lights indicate... solid on, flashing, off or burned out perhaps?
