Auto LSD feature
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jm3280, Feb 11, 2010.
  1. Feb 11, 2010 at 3:55 AM
    jm3280
    jm3280 [OP] Well-Known Member
    Jay
    Allentown, PA
    2010 TRD Off Road
    I have a 2010 TRD Off Road and they have this Auto LSD feature that scared the crap out of me when I drove it the other day in the snow and it started to spin some tires and this thing kicked in. Anyone explain this feature in normal words other than what the dealership attempted to do? It made some grinding noise and beeps and the dealership said that is what it is suppose to do. Had a 2006 and it did not have this feature. Thanks
  2. Feb 11, 2010 at 4:09 AM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    that is the stability control kicking in. imo it works awesome. it kicks in when the tires are slidding. it is designed to straighten you up. each tire brakes seperatly.
  3. Feb 11, 2010 at 4:13 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    I am still reading up on the strategy of this feature, so I will leave room for better understanding. It is more than just Auto LSD.
    The truck you have (same as me) also has some stability and traction features that can kick in. When wheel slip is detected on any wheel, it can actually perform and ABS apply to that wheel. That is the "grinding" that you are hearing. It is the brake actuator and release solenoids turning on and off while the ABS pump runs to provide pressure. This can apply and release the brakes quickly to the slipping wheels which will transfer the torque to the wheels that still show traction (not slipping). It is not really "grinding" but a buzzing of the solenoids which can turn on and off MANY times a second.
    I was playing with mine and found that while accelerating in a turn on slippery surfaces the system tries to keep the truck in a controlled "power slide". I had a momentary feeling of being fast and furious :)
    The beeping is feedback for the driver that vehicle stability and traction are abnormal so that you can also back out of the throttle to maintain control.
    HTH
  4. Feb 11, 2010 at 4:15 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    It works exactly as it is supposed to. Mine got tested last night and again this morning on the way to work. Where I used to have to use 4WD on my 1st Gen, I can stay in 2WD and have very good control! Of the 5 toyota trucks I've owned, this one has the best 2WD traction of any.
  5. Feb 11, 2010 at 4:49 AM
    jm3280
    Jay
    Allentown, PA
    2010 TRD Off Road
    Sounds good, thanks everyone
  6. Feb 11, 2010 at 4:54 AM
    adktacoma
    adktacoma Well-Known Member
    danny
    upstate new york
    09 trd sport bsp
    stock (for now)
  7. Feb 11, 2010 at 5:29 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Just make sure you turn it off if you are screwing around. Otherwise you will munch your brakes.
  8. Feb 11, 2010 at 6:27 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    So am I missing something? Are you talking about LSD (limited slip differencial) or VSC (vehicle stability control)?
    I'm thinking my 07 TRD Sport has LSD and I can't turn it off. It does not, however, have VSC which (if I knew about when I went looking for my first Tacoma I would have bought) can be turned off with a dash mounted switch.
  9. Feb 11, 2010 at 6:51 AM
    dalsmthme
    Ithaca, NY
    You do not have the same set up as us with '09+ trucks. Our trucks no longer have a true LSD in the differential. They have open differentials that rely on the brakes to simulate an LSB. The problem is, if you don;t turn it off and you go out an pwer slide in a snowy pakinglot it is working the brakes pretty hard in either the VSA or LSB modes. If it is turned completely off you don't have to worry about extra wear on the brakes.
  10. Feb 11, 2010 at 7:00 AM
    AZCOMA
    AZCOMA where can't I go?
    Kacey
    Laveen
    05 Preunner sr5
    2.5 saw co's, n-fab bed cage rear tire mount,new head unit and 10"sub,285/75/16 nittos on M/T wheels,H.I.D.'s...The next mod is T.C. long travle kit,Deavers and glass all the way around.
    Lsd ftw
  11. Feb 11, 2010 at 7:10 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    oh no.... here we go again! :)
  12. Feb 11, 2010 at 9:21 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Mark (and any others): If you have 4WD, why are to refusing to engage it, and instead make 2WD (with AUTO LSD) work so hard? You will have less breakdowns if you use the 4WD and let TRAC and A-TRAC take you anywhere without having to push the limits of the 2WD systems. Speed will break things.
  13. Feb 11, 2010 at 9:28 AM
    David K
    Actually, that thread is more for the non-TRD Off Road 4WD Tacomas that don't have A-TRAC and want LSD when in L4... so they do the yellow wire mod. to give them TRAC in L4.
    Here is the thread with details on all the drive modes for '09 + Off Road 4WD Tacomas: http://www.tacomaworld.com/forum/te...uto-lsd-explained-easy-understand-i-hope.html
  14. Feb 11, 2010 at 9:40 AM
    TOOLMAKER
    TOOLMAKER Member
    Michigan
    2010 ACCESS CAB SR5 OFF ROAD PKG
    Mine did the exact same thing on the way home from work last night, scared the crap out of me too. First thought was something broke or was about to.
