Auto LSD on with Trac off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brianjjeffries, Nov 28, 2016.
  1. Nov 28, 2016 at 2:56 PM
    brianjjeffries
    brianjjeffries [OP] Well-Known Member
    Brian
    Los Angeles, CA
    2016 Tacoma TRD Sport 4x4
    This is just a matter of curiosity.. It finally rained in socal recently so I wanted to see how my truck handled during a slide and yeah.. all kinds of crazy braking happened.. With everything off, I just got the 1 tire fire which is even more annoying.
    That being said, is there a way to get auto LSD to stay on while traction control is off?
  2. Nov 28, 2016 at 3:32 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    do not think so (maybe i am wrong) that's why someday i am going to re gear and put if a good old fashion posi traction 3rd member.
    BSFord and brianjjeffries[OP] like this.
  3. Nov 28, 2016 at 3:40 PM
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    The OR MT stays in auto lsd if you turn off A Trac.
  4. Nov 29, 2016 at 7:32 PM
    brianjjeffries
    Brian
    Los Angeles, CA
    I am assuming you mean Off-Road not sure what the MT is haha. But I have the Sport 4x4.
  5. Nov 29, 2016 at 8:26 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Manual Trans
  6. Nov 29, 2016 at 9:57 PM
    Sparky2
    Sparky2 Well-Known Member
    Keith
    2016 Tacoma TRD
    Turn off atrac (a quick push of the traction control button) and you'll get auto LSD (takes a second to work). Mine throws 2 wheel roost this way. No idea what it does on pavement.
    Hold down the button for several seconds and you're left with a fully open diff and no braking nannies. (Mine peels one strip of grass in this mode)
    Maybe you just held the button too long. It should do donuts with the auto LSD on.
    tcjacado, Pportera and Humboldt_Homie like this.
  7. Dec 6, 2016 at 3:44 PM
    brianjjeffries
    Brian
    Los Angeles, CA
    I just tried this while out in the snow.. just pressing the button and tried it and for the first few seconds was 2 tire fire then after a few seconds of spinning it shut me down and the trac light flashes. When the LSD is engaged you can feel all the braking bs going on. On second attempt same thing, few seconds of LSD using brakes then it shuts me down. in 4x4 I get fully open dif, auto lsd didn't even work. Either I am doing something wrong or the sport is anti off-road.
  8. Dec 6, 2016 at 4:23 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    you have to be at a full stop in order for it to turn off. and hold the button down for a few seconds like @Sparky2 said.
    David K likes this.
  9. Dec 7, 2016 at 9:36 AM
    brianjjeffries
    Brian
    Los Angeles, CA
    So there is no way to get auto lsd to work in 4HI? Been doing a lot of reading the features the OR gets of the Sport. I guess there is even a mod to get ATRAC in 4Lo.. but I dont know how legit that is with the 16.
  10. Dec 7, 2016 at 11:32 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    wait...what. Why would you need LSD with 4wd active?
    BSFord likes this.
  11. Dec 8, 2016 at 8:55 AM
    brianjjeffries
    Brian
    Los Angeles, CA
    Because in 4HI I had fully open diff, so in my opinion, what difference does it make having 2 rear spin over 1 front 1 rear? Either way I sat there spinning in 2 and 4HI both times only spinning 2 tires on a not very steep snow incline.
    Maybe Auto LSD would not help me in that situation.. But I would feel better knowing at least one more tire is getting power when I use 4x4
  12. Dec 8, 2016 at 9:37 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    push the traction control button once while in 4HI and it should go into TRACOFF. This is just like Auto LSD
    tacomatime and winterwolf like this.
  13. Dec 8, 2016 at 9:46 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Interested in the outcome of this. Toyota marketed the Sport as having an LSD....come to find out it is not a mechanical LSD. If it doesn't work in 4WD, its bullshit due to the reasons in post 11!
    Anyone ever swapped a TDR OR rear diff in to a sport? Can the ECU be reflashed to work with the locking rear diff?
  14. Dec 8, 2016 at 9:47 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Guys, guys... of all these posts, I think only Z50king had a good answer.... until he questioned it!
    I have written out all the traction control selections and how they work a zillion times. That's okay, it gives me something to do when I am not working!
    brianjjeffries wrote: "That being said, is there a way to get auto LSD to stay on while traction control is off?"
    A: "AUTO LSD" IS traction control! Traction control is limited slip. Slipping tires have no traction.
    Let me continue with some clarifications of names:
    AUTO LSD is traction control/limited slip without engine regulation, in 2WD.
    TRAC OFF is the SAME but in 4WD-HIGH (2009-2011 it was called TRAC and didn't require button push).
    Marcoc likes this.
  15. Dec 8, 2016 at 9:51 AM
    David K
    ALL Tacomas (Sport, Off Road, SR, Base) have AUTO LSD and TRAC. In 4WD they have TRAC OFF and TRAC. TRAC OFF is TRAC with engine regulation OFF, so more power while still braking the spinning tires.
    Yes, terrible names Toyota used.
  16. Dec 8, 2016 at 9:55 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    I only know as much as I do about the names due to your write ups on every thread that this comes up in....
    I know what to press and what the lights mean while I'm in the truck, but I can't remember when sitting here at my desk at work...
    David K[QUOTED] likes this.
  17. Dec 8, 2016 at 9:56 AM
    David K
    AUTO LSD is a 2WD limited slip mode.
    A-TRAC is a 4WD-LOW RANGE mode that is close to the same traction as front and rear lockers.
    TRAC OFF is a 4WD-HIGH limited slip mode.
    TRAC is the standard mode in 2WD and 4WD-HIGH. It is limited slip LITE (uses brakes and engine regulation to slow tire spin).
    *2009-2011 do not have TRAC OFF by that name or require a button push.
  18. Dec 8, 2016 at 10:00 AM
    pjensen641
    Boone, IA
    OK, so in 4WD high, it will use the rear brakes to limit rear diff slip if I am reading correctly. That is what I expected, but haven't tried it yet. Thanks for the info gents.
  19. Dec 8, 2016 at 10:00 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Reading this makes me miss my Jeep sometimes. 2wd-4wd-4lo, Locker on, Locker off..Easy
  20. Dec 8, 2016 at 10:02 AM
    David K
    Yikes!
    A-TRAC is an L4 (4WD LOW RANGE) only system. It has its own button. It should be pressed in anytime you are in low range for maximum traction.
    AUTO LSD is a H2 (2WD) system, it is activated by a quick push of the VSC OFF button.
    You must stop moving before holding in the VSC button to turn off the VSC and traction control. Never have a reason to do this. Spinning tires are a waste of energy and rubber. That is why all new cars have TRACtion control systems.
