Auto LSD question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDSPORTtaco, Jul 7, 2010.
  1. Jul 7, 2010 at 6:28 PM
    TRDSPORTtaco
    TRDSPORTtaco [OP] Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Whenever I am driving through the sand dunes or up and down the river my truck starts to feel like its going to get stuck because it slows down so much but I never get stuck. So my question is:
    Does the Auto LSD slow you down when driving in stuff like deep sand, mud, etc.. So that you wont lose traction and get stuck by transferring all the power to the wheel that's not starting to spin thus causing you to slow down?
  2. Jul 7, 2010 at 6:35 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    With my truck being a Sport I don't have the option of turning it off. As far as I know.
  3. Jul 7, 2010 at 6:46 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    you can turn the lsd off, press the lsd button then it will say auto lsd then press and hold it again and it will turn the lsd off
  4. Jul 7, 2010 at 7:01 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    I have a 2006 so I dont have any special buttons besides the bed outlet and fog lights.
  5. Jul 7, 2010 at 7:09 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Hmmm.. I dont think my truck even has the auto LSD now.
  6. Jul 7, 2010 at 7:12 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    you might just be losing traction and spinning in the sand.....
  7. Jul 7, 2010 at 7:13 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Ok I guess I have a mechanical limited-slip rear differential.
    How does this work?
  8. Jul 7, 2010 at 7:15 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Grrrrrr.... Time to sell my sport and get an Off Road
  9. Jul 7, 2010 at 7:35 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Well I've taken my Sport out on sand dunes, up all sand and mud river beds (with and without water flowing), up rocky creeks, up steep ravens, across rocky terrain while visiting family in Moab.
    I have yet to get stuck. I just dont know my truck as well as I should I guess.
  10. Jul 7, 2010 at 8:00 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    How many miles on the truck and when did you replace rear diff fluid ?
  11. Jul 7, 2010 at 8:02 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    I just hit 80k last week and I've never replaced it and don't know if the original owner has either (im 2nd owner)
  12. Jul 7, 2010 at 8:06 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    I believe it's every 60k?
  13. Jul 7, 2010 at 8:07 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Depending on how much you wheel
  14. Jul 7, 2010 at 8:08 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Wow. You should replace your rear diff, front diff, and transfer case oil as soon as you get a chance. The maintenance book says to do it every 30K miles. I just swapped mine out a few months ago. Not hard at all, you can easily do it yourself.;) But with as many miles as you got on your truck and as much as you use your 4-wheel drive, you should def look into changing out the fluids soon.:eek: I also have an 06' Sport 4x4.
  15. Jul 7, 2010 at 8:25 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Hmmm I guess tomorrow Ill be doing some fluid maintenance since I do use 4 wheel drive often. Thanks for the tip
  16. Jul 7, 2010 at 8:28 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah no problem but make sure you use the right stuff for the rear diff. There has been many threads on people getting all kinds of noises from the rear diff cause of the gear oil and additives they have used.:eek:
  17. Jul 7, 2010 at 8:31 PM
    BlueT
    NorthEast
    Well there is your problem. Book says 30k but does not distinguish between lsd or non lsd. You are probably 50K miles or more overdue which means cluthcpacks could be getting gunked up. To test if your LSD still works
    1. lift your rear axle with vehicle in 2wd and front wheels blocked.
    2. put torque wrench on one of the lug nut and set it to 150 foot - pounds
    3 Try to turn the wheel
    If it takes less then 100 foot-pound to turn wheel then your LSD probably took some damage.
    if it is like 20 foot-pound only then its toasted.
  18. Jul 7, 2010 at 8:34 PM
    night_angel
    night_angel Well-Known Member
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    ECU FT500, JBA Headers, 100% Offroad
    I had the same problem,and I change my diff. oil and I had no problem more...
    in the future I want to put the a Locker, is the best solution...
  19. Jul 7, 2010 at 8:41 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    I will try this first thing tomorrow morning.
  20. Jul 7, 2010 at 8:57 PM
    BlueT
    NorthEast
    Also a piece of advice.
    When you buy used car, regardless of the miles first thing is to replace all the fluids with new ones and do all the required maintenance.
    Every used car I bought went to garage first for overhaul. Most of the time people when they know they will sell a car they neglect everything.
