Auto LSD vs. "Real" LSD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tguil, May 15, 2018.
  1. May 15, 2018 at 4:47 PM
    tguil
    tguil [OP] Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Been driving vehicles with mechanical LSD's for most of my driving career...over 50 years. They always worked for me. I really appreciated an LSD being an addition to 4WD. Now about the auto LSD's on the Gen 3 Tacomas. As I understand it, it is not all that "automatic". It has to be intentionally engaged by the driver and then it is only used when the truck is in 2WD. My question/comment...Why even bother using it if you have a 4WD Tacoma? if you are in a situation where you need more traction, just twist the 4WD dial and you are good to go. Might as well have a totally open rear differential.
    tacoguy88 likes this.
  2. May 15, 2018 at 4:51 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Sigh. Toyota and their fake BS traction-control-based LSD. I turn TRAC completely off on my truck.
  3. May 15, 2018 at 4:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    VSC and traction control. It is used to keep the shiny side up.
  4. May 15, 2018 at 6:22 PM
    tguil
    Nebraska
    The "shiny side up" is good. By why the "automatic LSD" that is not automatic?
  5. May 15, 2018 at 6:31 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    They call the same basic principle, different things depending on what your doing. Probably marketing to make is sound like you have more “gizmos” on the truck.
    It’s all traction control, ie apply brake to the side that’s spinning faster. So it does actually works in 2wd and 4wd, it’s just called different things.
    Night hunter, Dirty Harry and Mr-Paul like this.
  6. May 15, 2018 at 6:49 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Who needs traction control and LSD when we have Beavis and Butthead?
  7. May 15, 2018 at 6:59 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    My experience for whatever its worth; I was waiting to turn right when a girl turned in front of a minivan entering the intersection. Minivan hit her and both came towards me. I saw it coming and instincts kicked in. I gassed it and tires spun. After getting my bed repaired, I went and had a truetrac installed in the rear diff.
    Should've done it way before that. Truck got stuck once crossing a small ditch when one of the rear tires lifted. Had to lock into 4wd to get out.
  8. May 15, 2018 at 7:03 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    That was peyote
  9. May 15, 2018 at 7:04 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Ok so it fits this thread. It wasn't "Real" LSD. :rolleyes:
  10. May 15, 2018 at 7:09 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Lol
    Never tried the cactus buttons myself.
  11. May 15, 2018 at 8:20 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    It's par for the course these days. Everything up and down list is open diffs traction controlled systems. They're getting better then they were in the past, they react quicker and more accurately. It's really the reason newer supercars are rolling off the assembly line at 600+ hp and being even remotely drivable by the most mediocre capability with a lead foot. But still, nothing beats good old school mechanical systems and a skilled driver. I still miss my jeep to this day with its lack of any electrical nanny's and mechanical controls.
  12. May 15, 2018 at 8:34 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This.
    Auto LSD has nothing on a mechanical truetrac. On my To-Do list.
    Automatic brake proportioned systems are all reactionary. The Tacomas isn’t as bad as some others I’ve driven. But one wheel has to excessively spin beyond a threshold before brakes kick in to slow the offending wheel down to get power to the other wheel. If at a stop and you punch it, auto LSD spins one tire before determining the tire is spinning beyond the threshold and engaging the brakes so that power is transferred to the other tire, if excessive engine power may be reduced. Truetrac both tires always spin the same direction, punch it and both tires spin forward.
    MattCowsmasher and Dirty Harry like this.
  13. May 15, 2018 at 8:47 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    And this engine cut is what many owners have reported about when trying to merge. Best to turn TRAC off if you're gonna be doing any sketchy city maneuvers.
  14. May 15, 2018 at 8:53 PM
    StormShadow
    StormShadow Well-Known Member
    Anaheim, CA
    2008 White Tacoma TRD Sport Going Off-Road
    Demello Front Bumper, Superwinch 9500 SR, PIAA 510 Fog, Relentless CB Hood Mount, Cobra 75 WX CB, CBI Ditch Light Mount with Rigid HyperBeams, Throttle Body Riser, K&N Intake, Flowmaster Super 50 Dual Exhaust, BacFlip Bed Cover, Custom Fab (Jack, Shovel and Axe Mount), TechDeck Base for Ram Mounts, Custom fab aluminum tailgate panel, Pelfrey Built aluminum skids, Demello sliders, twin ARB compressor, Custom fab camp light, HAM antenna with handheld, Custom Fab traction pads and bed mount, VTX Rogue 16's in bronze, 18 gallon onboard water storage and DC pump, 12v additional pusher radiator fan, ABS kill switch, Wilco tire carrier, . . . . . . .
    I have a 2008 Sport with the last year of the mechanical LSD (Real LSD). I'm pretty happy with the mechanical. It seems like I keep good traction in the rear even when going off-camber. Both tires turn even at slow speed. The front is where I loose the traction and spin. ARB lockers have been in my shopping cart for a while for the fronts.
    With that said . . . I would love to have that rear positively locked, but if I add the ARB I would loose the mechanical LSD for everyday driving. If it was brake controlled LSD, I could put lockers on the rear and keep road traction with the brake assist every day.
    I think that is the best benefit with the electronic over the mechanical for my use.
  15. Oct 3, 2018 at 2:41 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Good info thanks everyone. Was curious about this as well since I have a 2006 Tacoma with LSD. I've been off-road quite a bit and haven't been stuck, sometimes off camber. I wasn't sure how much the LSD is helping off road since I don't really hear anything going on and don't need to push a button to engange it. I think it's doing the job, along with good aired down tires and a (good) driver :rofl:
  16. Oct 3, 2018 at 2:44 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    It’s a huge benefit to traction off road. I can tell a YUGE difference from open stock electric traction control system to having the trutrac best mod I’ve made to mine.
    dirtnsmores[QUOTED] likes this.
  17. Oct 3, 2018 at 4:46 PM
    StormShadow
    Anaheim, CA
    I only loose traction in my front off-camber. My rear tires turn pretty equally even when one is in the air at crawling speed. Pretty cool since my buddy with a TRD Offroad needs to put his in 4Lo before engaging his rear locker. In most cases, 2wd with mechanical LSD is all you need offroad. One of my tallest staircase climbs was behind a 2wd LSD 4Runner. I elected to go 4wd.
  18. Oct 3, 2018 at 4:53 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    It uses the brakes to simulate lsd
  19. Oct 3, 2018 at 4:59 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    4WD is really only one tire in front and one in the rear 'working' and that is only when they have no traction! Still, that is better than 2WD with only one tire working! 4WD is twice the traction of 2WD and that is why you can go further.
    Now, the problem is traction loss... slippery surface or a tire in the air! Limited Slip (be it mechanical like the 2005-2008 Sport Tacoma or electronic like ALL Tacomas since 2009) slows a free spin and shifts some power to the tire that has traction. This is better than open differentials. Better still is a locking differential which turns both tires the same regardless of traction. The A-TRAC system also does this using the brake system.
    The 2009 and newer Tacomas have TWO levels of limited slip: TRAC and TRAC OFF (called AUTO LSD in H2). There is also a no TRAC choice, called VSC OFF. TRAC is brake force and engine regulation to control tire spin. TRAC OFF (bad name) is brake force only. The engine regulation is off for more power to the traction tire(s).
    Some 2016+ Tacomas report better traction with TRAC than TRAC OFF... so a change may have been made? Just test them all on difficult hill climbs and other conditions.
