auto LSD- what is the point?
Discussion in 'Technical Chat' started by stan powers, Nov 8, 2009.
  1. Nov 25, 2009 at 12:38 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    no it is not it is an add-on that you need to install.
    thanks for the info
  2. Nov 25, 2009 at 12:39 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Auto LSD is on non- offroad package. the offroad package has a rear locker not LSD
  3. Nov 25, 2009 at 12:45 PM
    Yoytoda
    Roland
    completely stock
    ok heres a quick explaination:
    2wd- the truck has lsd off and VSC on. when you hit the VSC button once the lsd comes on VSC turns off. When you press and hold, LSD and VSC is off.
    4hi- TRAC is activated. TRAC is the combination of LSD and VSC. Press and hold the VSC button for 3 seconds and TRAC is turned off.
    4Lo- TRAC is off by default and can only be activated by the yellow wire mod
  4. Nov 26, 2009 at 7:58 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Thanks yoytoda - my vsc icons on cluster never light up, not even at start up. I thought might have been a problem.
    Do u know if the offroads have a limited slip diff at all? that kind of sucks, really. i would use that much more than a locker - should have gone with the sport, i guess!
  5. Nov 26, 2009 at 10:30 AM
    Yoytoda
    Roland
    completely stock
    UHH dont you have ATRAC???
  6. Nov 26, 2009 at 10:39 AM
    swise
    swise TRIFECTA!!!
    ohio
    I dunno - i have factory window sticker that shows sr5 package and off road package installed including rear locking diff., but nothing about atrac.
    I only have push buttons for rr locking diff , 110 volt/inverter, and fog lamps on the left hand panel by your knee. The owner manual reads like all of these things are standard equiptment, so I'm confused about what I actually have installed on Mr. Truck.
  7. Nov 26, 2009 at 11:02 AM
    Yoytoda
    Roland
    completely stock
    do you have a Atrac button next to the mp3 input?
  8. Nov 26, 2009 at 11:38 AM
    swise
    swise TRIFECTA!!!
    ohio
    no, I dont think they had mp3/aux inputs till 09+ unless maybe on the jbl audio package. no button up there for atrac:(
  9. Nov 26, 2009 at 12:28 PM
    Yoytoda
    Roland
    completely stock
    well a locker is much more capable than a lsd. Read your owners manual and get more familiar with the truck. All the info is here and in that manual
  10. Nov 26, 2009 at 12:37 PM
    swise
    swise TRIFECTA!!!
    ohio
    Thanks for your help - btw I found a brochure for 08, does not list atrac as any option untill 09. I dont think it was available in 08. just lock diff for offroad pack, or lsd for sport model package. I could just go to the dealer and ask, but I would rather look like a moron here than in person
  11. Nov 26, 2009 at 12:41 PM
    Yoytoda
    Roland
    completely stock
    I kinda figured the year was the reason. My 2010 has TRAC which is lsd front and rear. Works awesome...ATRAC is a better version of trac that is on 09-10TRD OR
  12. Nov 26, 2009 at 1:28 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    my offroad has auto lsd
  13. Nov 26, 2009 at 1:36 PM
    Yoytoda
    Roland
    completely stock
    you dont have an 08.
  14. Nov 26, 2009 at 1:40 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    true..
  15. Nov 29, 2009 at 6:28 PM
    #35
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Needed to be said............+rep
    (Can't stand when some people do long winded explanations that are totally wrong......)
  16. Dec 4, 2009 at 4:18 PM
    #36
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    LOL! Funniest thing I read all day, thanks.:rofl:
  17. Dec 4, 2009 at 4:26 PM
    #37
    Yoytoda
    Roland
    completely stock
    Hey!!! truck twin...
  18. Dec 4, 2009 at 4:33 PM
    #38
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Don't the 2010 TRD Sport's have an honest to goodness LSD in in the rear that is not controlled by the braking system, in which case you couldn't "turn it off" so to speak?
    I kinda wish they hadn't called it "Auto LSD" It seems to cause a lot of confusion, especially since it has absolutely nothing to do with a limited slip differential. It's just similar behavior from a totally different technology.
  19. Dec 4, 2009 at 4:36 PM
    #39
    Yoytoda
    Roland
    completely stock
    no, even the sports went over to the electronic type for 09-10 IIRC.
    Its not a bad thing though, it works better than the mechanical style IMO.
  20. Dec 4, 2009 at 4:46 PM
    #40
    xodeuce
    Alabama
    2004 UZJ100
    Ah, learn something new every day. The dealerships here TOTALLY misrepresented that when I was looking!
