Auto LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bikinit, Apr 16, 2012.
  1. Apr 16, 2012 at 10:16 AM
    bikinit
    bikinit [OP] EXTREME...poser
    Mass.
    '12 TX Pro DC SB V6
    First day here and a question already.... Was driving about 60 mph and went over a bump - wheels left the ground briefly and all hell broke loose with the auto lsd system I think. It vibrated a lot and slowed me down - it regained composure and was fine after that - possible the feature was accidently engaged? :confused:
  2. Apr 16, 2012 at 10:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That would have been your stability control kicking in
  3. Apr 16, 2012 at 10:20 AM
    bikinit
    Mass.
    '12 TX Pro DC SB V6
    Okay, thanks, any thing to keep an eye on, or should I just make sure it is not engaged? My last taco didn't even have ABS so the sensation was unnerving...:bananadead:
  4. Apr 16, 2012 at 10:26 AM
    bikinit
    Mass.
    '12 TX Pro DC SB V6
    Will do - but it could get dangerous at highway speeds...
  5. Apr 16, 2012 at 10:47 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    It was the VSC making sure you wouldn't spin out of control, ;)
    AUTO LSD rquires you push the VSC button once, for a stronger limited slip to help you move from a stop in 2WD. It is TRAC but without engine regulation.
    To turn off TRAC and VSC, stop the truck and press and hold down the VSC button... about 3-5 seconds, until the indicator light comes on.
    It goes back to normal anytime you restart the truck or re-press the button.
    Click the link below for more details on all the drive mode options...
