Auto LSD?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by coachingkidsfootball, May 1, 2016.
  1. May 1, 2016 at 2:44 PM
    coachingkidsfootball [OP] New Member
    2016 SR5 4x4 V6
    This is my first Tacoma and have been reading and researching the Auto LSD function but still have a question. Have a 2016 sr5 v6 4x4 auto. When in 2wd I press the traction control button and trac off and auto LSD show up on instrument panel. When in 4wd high and press the botton only trac off shows up. I did not hold the button down but just touch it. I thought that we had a LSD in 4wd high. So this means open differential in 4wd. If this is the case I may be doing a lot of walking for asking to get pulled out a lot. Will be going down wet field roads on a daily basis.
    The sale person also said it had LSD in 4wd.
    Thanks for the help!!
    shift96 likes this.
  2. May 1, 2016 at 2:48 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    walking, no. that's why you have a locker err wait you have the sr build so no locker.... time to contact arb?
  3. May 1, 2016 at 2:55 PM
    eon_blue
    Azusa, CA
    Unfortunately this is why you can't ever trust what a salesman tells you, in my experience they usually don't know anything about these trucks outside of the basic specs, and even then that's still not something I'd rely on them for exclusively.
    If having a no-slip or limited slip differential is necessary for you on a daily basis, I'd really look into getting a selectable locking rear differential. Like mentioned above, ARB makes them and they are very reliable, even better than a limited slip. My understanding is that LSD's were designed more for everyday driving use, not so much for offroad use. A locker is a better bet for that.
    Seabass likes this.
  4. May 1, 2016 at 5:40 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    @DavidK
  5. May 1, 2016 at 5:54 PM
    the phew
    the phew Well-Known Member
    TRAC brakes a slipping wheel in 4high, so you'll be fine.
    Auto-LSD vs. TRAC is just Toyota marketing nonsense; both are effectively the same thing. And neither is anything special either; AFAIK every passenger vehicle currently sold in the U.S. has electronic brake-based traction control. Toyota is the only company that calls theirs a "LSD", a term other companies reserve for clutch-based mechanical/electromechanical units.
    You only have truly open diffs if you turn off TRAC/Auto-LSD with the button.
    0uTkAsT likes this.
  6. May 1, 2016 at 7:10 PM
    2016 SR5 4x4 V6
    In 4HI with TRAC do you get engine deactivation if you tires start to spin. This is all good to know before I get in the mud. Thanks for all of the help!
  7. May 2, 2016 at 11:22 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    yes, confusing..called LSD but can only drive 5MPH when engaged because it is totally locked up. which is ?
  8. May 2, 2016 at 11:27 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    No. You can lay into the pedal and spin through things.
    Yellow wire mod also gives you TRAC in 4lo rather than open diffs. Search for it and read up on it. I'm not sure if it's exactly the same in 3rd gens.
  9. May 2, 2016 at 12:40 PM
    OZ-T
    Peter North
    British Columbia
    Thats the locker , not the same thing
    Where's @DavidK
    So much incorrect info in here
  10. May 2, 2016 at 5:11 PM
    2016 SR5 4x4 V6
    So in 4HI you have trac and no engine deactivation but in 2wd you would still have trac but engine deactivation. Press traction control button and in 2wd you have auto LSD???
  11. May 2, 2016 at 8:24 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Auto lsd is ONLY available in 2hi. TRAC OFF is auto lsd on all 4 tires in 4hi.
    You can turn it all off by stopping and holding the Traction control button for a few seconds. But VSC will still take control if it senses something crazy. You can never completely turn off VSC, even though the book says it's turning off traction control and VSC.
    4LO is open diffs on all models except for the OR unless you yellow wire
  12. May 26, 2016 at 4:40 PM
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    wait what? auto lsd is front and rear on 4hi when trac is off?
    also, on the yellow wire mod does 4lo default to open diffs?
    or is that for the 2016s?
