Auto LSD?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sistersinhim, May 3, 2017.
  1. May 3, 2017 at 11:42 AM
    sistersinhim
    sistersinhim [OP] Member
    2017 SR Tacoma
    As you can tell, I am a brand new Tacoma 4x4 owner and don't know half of what I should. I will probably never run the 4 WD, so should I be running in the Auto LSD mode or the ATC mode?
  2. May 3, 2017 at 11:44 AM
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
  3. May 3, 2017 at 11:45 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  4. May 3, 2017 at 11:50 AM
    Humboldt_Homie
    Humboldt_Homie If you're not first, you're last.
    16 TRD OR DCLB
    Bilstein 6112 front, 5100's rear with blocks, camburg UCA, 17" XD's with 285/70/17 AT 3's and a blackout front grille.
    Auto LSD is an aftermarket feature that will lower a robotic arm with blotter paper from the sun visor and apply to your tongue for you.
  5. May 3, 2017 at 11:55 AM
    smitty99
    Scottsdale
  6. May 3, 2017 at 11:58 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
  7. May 3, 2017 at 12:04 PM
    smitty99
    Scottsdale
    I'm going to go out on a limb and say MOST people with 4x4s are not doing 10 miles per month in their vehicles and we don't have 4x4s breaking down all over because of it. It's a nice suggestion but it isn't a requirement to keep the vehicle operating.
    Farmer_Ted likes this.
  8. May 3, 2017 at 12:06 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Sorry but it's better for the vehicle if you do, fwiw - that is a legitimate piece of information for anyone new to 4wd, take it or leave it
    :thumbsup:
  9. May 3, 2017 at 12:09 PM
    smitty99
    Scottsdale
    It's also better for the vehicle to park in the garage. ( as opposed to on the street)
  10. May 3, 2017 at 12:12 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    :rofl:
  11. May 3, 2017 at 12:15 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I didn't know the SR had auto LSD?
    Long story short, leave it in normal mode unless you get stuck. This leaves traction control on which will cut throttle as wheel slip occurs or if it senses the truck start to drift.
    Push it once if you are stuck or going slow and in danger of getting stuck. This will engage auto LSD and reduce traction control so that you can spin the wheels a bit more if needed to power out.
    Push and hold it for many seconds to turn everything off if you want no intervention....like when the urge to do donuts hits.
    I believe this is how it works. Honestly, I've never had the need. When it gets slippery and normal mode isn't working, I flip on 4-Hi and that's been sufficient.
