Auto Max AC Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dano.oh, Dec 19, 2013.
  1. Mar 8, 2016 at 11:38 AM
    #61
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Anybody have any words of wisdom here? I'm at a loss on what to do other than back out the mods to see if it fixes the problem.
  2. Mar 8, 2016 at 6:42 PM
    #62
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    My only words of wisdom are to do one mod at a time so that if you mess something up it's easier to track down. Can't help with your specific problem tho. I'd undo everything and see if that solves your problem. Good luck.
    Norton likes this.
  3. Mar 9, 2016 at 11:11 AM
    #63
    DRP6833
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Thanks, Sizzle, that's what I planned to do. Reversing the defrost mod is easier so I'll do that first and go from there.
    SIZZLE likes this.
  4. Mar 20, 2016 at 7:22 AM
    #64
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Has anyone other than OP tried to remove the brown wire pin from the connector? I tried yesterday, no luck. Did not want to cut the wire and leave that hanging out of the connector, so I gave up for now...lame, I know...
  5. Mar 20, 2016 at 9:57 AM
    #65
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    I just cut it and let it hang. Easier to splice back together if you ever wanted too. Tape it up and you're good to go. I also didn't solder the new connection. Please don't take away my Toyota card :)
  6. Mar 20, 2016 at 10:45 AM
    #66
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Did you use the 'cut both wires & splice with butt connectors' or just cut the brown wire & remove the insulation from a spot on the pink and splice?
  7. Mar 20, 2016 at 11:49 AM
    #67
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    Cut both and butt splice. It's not a mission critical system so I don't mind if it's not professional quality. It took me five minutes and it's worked perfectly so far.
  8. Mar 20, 2016 at 12:57 PM
    #68
    imageomega
    imageomega Well-Known Member
    Jarrod
    Norton likes this.
  9. Mar 20, 2016 at 6:28 PM
    #69
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Exactly what I did, minus the zip ties. Those just seemed like overkill seeing the size of the wires, and the location & lack of tension on the wire loom. Took about 10 minutes, works as described. Thanks OP, very useful post!
  10. Mar 20, 2016 at 6:30 PM
    #70
    imageomega
    Jarrod
    I didnt do the zipties either. I did that center hole splice and soldered , but I was doing 4-5 mods at once so i had all the tools out and ready. Otherwise would have taped and been done.
  11. Mar 20, 2016 at 6:35 PM
    #71
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I looked for my soldering iron, without success, but again, these were such small wires, I figured the splice & tape were more than sufficient. If I find my soldering iron, I may go back and add the solder...
  12. Apr 3, 2016 at 6:16 PM
    #72
    BreakfastBurrito
    BreakfastBurrito Member
    Thanks OP worked like a charm on my 09.
    I am glad I am not the only one who hated that "feature"
  13. Apr 13, 2016 at 11:31 AM
    #73
    DRP6833
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Well I got to the bottom of this, and it turned out to be a pilot error. :facepalm:
    This message explains how to do the A/C Defrost mod for 2009+ Tacos. The first message in the thread in big red letters points to this info, but did I notice it? Nope. Anyway, things are working as intended now, just wanted to pass the info along.
  14. Apr 13, 2016 at 10:10 PM
    #74
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Just did this mod thx dan.ooh it's back to the way it works on my 07 sr5 frankly I saw it as not just a ridiculous inconvenience, but also a safety issue. Looking away from the roadway 2x to 3x a day for a few seconds to bump the temp dial up a notch or push both buttons.... everyone should do this ...... Thx dude
  15. Sep 14, 2016 at 10:36 AM
    #75
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    Another bump for a great and easy mod! Didnt even think to look this up when I purchased my '13 in June. Now that the weather has been cooler, I find myself turning the dial more often and accidentally switching to Max A/C too often.
    5 minutes with a quick splice, some electrical tape and a test session to make sure it worked and I could not be happier. Thank you to Dano.oh again!
    P.S. I didnt see this mod linked in the "2nd Gen Tips, Mods & More" page, which is likely why I didnt get to this until now. Any way of adding it?
  16. May 13, 2017 at 4:16 PM
    #76
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    Great mod, really didn't like kicking on the A/C when I turned the Temp Control all the way counterclockwise! Confirming this mod works on 2010 model year.
  17. Oct 16, 2017 at 7:19 AM
    #77
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Just did this on my 2015 and it worked great. I can't for the life of me figure out how to release the pins from the connector though, I had to improvise
  18. Oct 31, 2017 at 5:47 PM
    #78
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    I've always been bothered by this "feature", just have to find the time to fix it now.
  19. Jul 24, 2018 at 7:46 PM
    #79
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Revisiting this after a few years. It seems my recirc button no longer works...related, do you think?
  20. Jul 24, 2018 at 7:55 PM
    #80
    Taco'09
    Taco'09 Well-Known Member
    Its likely the ricirc servo located behind the glove box and on the air inlet and would be unrelated to the mod. The servo has a known history.
